Rollpin removal direction
Old Mar 5, 2022 | 01:05 PM
MarD250's Avatar
Which direction should I go?
Not sure if I should drive it from the other side that is already pinched
It looks like it's starting to come out but I can't drive it any further should I drive it back the other way?
Old Mar 5, 2022 | 02:25 PM
Is that the coupler for the steering?
If so put a little penetrateing lube on it and drive it back then out. Make sure your driver isn't to large for the hole.
Old Mar 5, 2022 | 06:18 PM
I don't remember them only going in or out from one side. Drive it back and forth until you get it free....
Old Mar 6, 2022 | 06:55 AM
MarD250's Avatar
👌 I'll give that a try...Thanks for the tip...
Old Mar 6, 2022 | 09:25 AM
It should be just a roll pin and Not a wedge pin.... It should come out ether way....
Old Mar 6, 2022 | 04:56 PM
To me it looks like the role pin driver is to large for the hole in the shaft.
Old Mar 6, 2022 | 08:22 PM
MarD250's Avatar
I have a different driver that I've been using a 5/16... I live in an RV park & the neighbors👎 complained about the noise from me banging on it! so I gotta find another place to work on it... What sucks is that I already removed the pitman arm off the steering gear & now I gotta put it back on so I can move the truck
Old Mar 7, 2022 | 06:40 AM
Removing that roll pin should not be that big of a deal get out a quarter inch driver and knock it out. Gets a replacement roll pin is no problem.
Kyle MacDonald
Mar 5, 2022 06:20 PM
DUGGER
Mar 28, 2018 04:19 AM
USMC45
Aug 26, 2012 07:11 PM
comcor_lxi97
Jan 16, 2007 11:06 PM
