Too much starter fluid??????
Old Mar 18, 2011 | 06:48 PM
frogjumper's Avatar
So I was trying to get my 73 cuda 318 starter and the fuel pump was not working. To get it to run, I sprayed starter fluid into the carb and ran the car for about 45 seconds. Now the car wont start. Did I cause damage?
Old Mar 19, 2011 | 04:48 AM
rdrunner1974's Avatar
starting
Does it still turn over? if so, try gas instead of starting fluid. Fix the fuel pump issue.
The starting fluid may have caused it to jump the timing. If it turns over, put a timing light on it to see if it's off.
Old Mar 19, 2011 | 08:25 AM
I don't understand how starting fluid will cause the timing to change.
However, if you actually "ran the engine" on starting fluid for nearly a minute, you may have caused the rings to dry out (no oil). I'd squirt a little oil in the plug holes and crank it over a couple of times.
I can't think why else starting fluid would ACTUALLY cause this situation. I would not think it would do something like cook the plugs, but have you looked at the plugs?
What does the spark look like?
More important, why did you do this, instead of using gasoline?
Old Mar 19, 2011 | 04:27 PM
frogjumper's Avatar
I did it because I did not know it would cause damage . I pulled a plug and it is dark black and very dry/ashy. I will change the plugs and try again. Anything I should while they are out or before I change them?
Old Mar 20, 2011 | 10:05 AM
OK. As I mentioned, I'd squirt a little oil into the cylinders and crank the engine over. If you have a "pump oiler" just a couple of pumps into each.
Buffalojoe426
May 14, 2010 03:42 AM
scotts74birds
Apr 15, 2009 10:02 AM
DartConvertible
Mar 17, 2008 05:22 PM
theaspenator
Feb 1, 2008 07:46 PM
ucfierocharger
Nov 20, 2007 07:16 AM
