Out of gas, never to run again...
Old Aug 15, 2013 | 11:17 AM
hewdge's Avatar
Here is the deal, im fairly new to this car, but not new to mechanics so please bare with what ignorance I may have.
Question 1: Is a 94 Plymouth Sundance in fact a "P Body"?
I just got this car off of a person who ran it dry on gas. The story is that they "ran out of gas and pulled to the side of the road." What I know, it was out of fuel when I got to the scene. I bring it back to the garage (trailer), put 3 gallons of fuel in it and nothing....
Into the trouble shooting I find that the fuel pump is still good, but the relay for the pump is getting no juice. It also has no spark. This is telling me that the "computer" in the car is preventing it from running probably because some kind of safety switch?
Question 2: Is there a safety switch of some kind that trips when the car is ran out of fuel?
Question 3: What do you think about this situation?
Thanks guys.
Old Aug 15, 2013 | 12:01 PM
I would check and make sure it didn't break the timing belt if it has one...
Old Aug 15, 2013 | 01:57 PM
First thing I do.... Check all the fuses.... Then you know your good to go hunting!
Check and make sure the pcm is getting power?
Yes that is a P/Body
Do you have the 1.8 or 2.2 ?
Old Aug 15, 2013 | 02:17 PM
slade's Avatar
what engine 2.2? there notoriose for timing belts and snapped cams. ask me how i know lol
Old Aug 15, 2013 | 06:00 PM
hewdge's Avatar
Yes it is a 2.2L
So I popped off the inspection plug from the timing belt cover and sure enough the top pull isnt spinning. Im about 99% sure its the timing belt.
My next question: This belt broke while the engine was running (does it happen any other way?lol) so I am wondering if I am at risk of finding valves and pistons smashed together? Is that a no interference type valve timing?
hewdge's Avatar
And also will that trigger something to shut down the fuel pump too?
Old Aug 15, 2013 | 08:12 PM
You won't get a crank signal
IT depends the single cam is non interference
The twin cam is an interference motor
Old Aug 15, 2013 | 08:17 PM
mr340's Avatar
IIRC that is a piston crusher, and if it was running at any substantial RPM there is sure to be carnage inside the cylinders. Sorry.
Old Aug 15, 2013 | 08:29 PM
You should be ok... No interference......
http://www.gates.com/part_locator/in...cation_id=3002
Old Aug 15, 2013 | 08:42 PM
mr340's Avatar
Sorry, I was incorrect, the 2.4 was considered the "freewheeling" motor which was supposed to be non-interference so to speak ,but had the "potential to cause piston damage"
Old Aug 16, 2013 | 06:35 AM
pro-tech's Avatar
The cam sensor is what send the signal to the PCM. There is no spark because the Dist. is run of the balance shaft and when the belt breaks (which it didnt they get loose and strip the cogs off as a rule) the shaft doesnt spin to drive the gear. It is a pretty easy job if you are mechanicly inclined. Are you sure this is a 2.2 most of them were 2.5L not that it makes much difference..Good luck if you have any questions dont hesitate to ask or PM me. I have been a Chrysler master tech for 35 years...Bill
Old Aug 16, 2013 | 06:40 AM
pro-tech's Avatar
slade, you are exactly right but the cam problems were fixed by 94 the early 2.2 had soft cams and the lifters would wear the cam and the cam also broke...Bill
Old Aug 17, 2013 | 05:51 AM
slade's Avatar
oo ok i know i broke a earlier one lol. and that 2.2 was interferance engine i put holes in the pistons of one
Skip31
Apr 30, 2013 08:11 AM
dodgenut7
Jun 16, 2010 03:42 PM
OHD
Apr 7, 2010 09:27 AM
67Polara
Aug 17, 2009 08:26 PM
Zach8200
Jul 9, 2009 05:54 PM
