ABS problem
The ABS light came on in my 99 Cirrus. My code scanner wont read ABS faults. Is there a way to troubleshoot the system without a dealer?
Nevermind, found the flexible line at the wheel had collapsed, acting like a bad caliper.
wish i coulda helped in helping figuring it out, but glad u got it taken care of
well, we both learned some thing here, pass it on. If you have a bad caliper, crack the bleeder. If the caliper retracts , its not the caliper. Check the flexible brake line, they do go bad.
FYI, the line did not go bad. The clamp that holds the line in place corroded, and the rust came in layers, and slowly crimped the brake hose! Pedal pressure will get the fluid past, but it wont go the other way! Big heads up cause heard this is also a Neon issue on front calipers.
The proportioning valves are known to go on the rear of those cars as well...just thought id chime that in as well. Had to deal with quite a few of those.
| All times are GMT -7. The time now is 10:21 PM. |
