Need help with where this fuel hose connects
Old 06-02-2013 | 08:49 AM
71mopar's Avatar
I just had to replace the fuel line on my 2004 Dodge intrepid which has the 2.7 liter engine. The line has a small pin hole leak in the nylon section up near where it clips onto the fuel rail. This is a common problem and should be a recall. Anyway I got the new Fuel line in and in the process somehow I disconnected the other line which I think is a vapor line. This line has a blue clip with a rubber hose with a metal nipple on the end.
I cannot find where this goes to.
Any help would be greatly appreciated
Thanks
Old 06-02-2013 | 09:32 AM
mr340's Avatar
You have a PM
Old 06-02-2013 | 09:39 AM
71mopar's Avatar
Intrepid fuel line pics
Here are some pics of the line I'm talking about.Need help with where this fuel hose connects-dscn0961.jpg
Old 06-02-2013 | 09:50 AM
mr340's Avatar
That looks like a vacuum or vapor line, where is is attached to on the other end?
Old 06-02-2013 | 09:54 AM
71mopar's Avatar
fuel line
I think its a return vapor line. It runs all the way back to the tank along side the high pressure fuel line. When I was pulling the high pressure line down to change I pulled this off by mistake and now can't find where it goes to. The high pressure has a green clip this one has a blue clip.
Old 06-02-2013 | 10:04 AM
mr340's Avatar
Vacuum canister line?
Old 06-02-2013 | 10:06 AM
mr340's Avatar
diagram:
Old 06-02-2013 | 10:14 AM
71mopar's Avatar
fuel line
It comes up the back of the engine from the tank. It has a blue clipped disconnect which changes to a hose approx 11" long with a metal nipple end.
71beeper
07-02-2014 06:53 PM
olibass1
04-04-2012 12:06 PM
jar84203
06-15-2010 10:39 AM
Dust'em
04-10-2009 04:45 PM
burnsy26
10-01-2007 02:35 PM
Quick Reply: Need help with where this fuel hose connects
