Need help with where this fuel hose connects
Old Jun 2, 2013 | 07:49 AM
71mopar's Avatar
I just had to replace the fuel line on my 2004 Dodge intrepid which has the 2.7 liter engine. The line has a small pin hole leak in the nylon section up near where it clips onto the fuel rail. This is a common problem and should be a recall. Anyway I got the new Fuel line in and in the process somehow I disconnected the other line which I think is a vapor line. This line has a blue clip with a rubber hose with a metal nipple on the end.
I cannot find where this goes to.
Any help would be greatly appreciated
Thanks
Old Jun 2, 2013 | 08:32 AM
mr340's Avatar
You have a PM
Old Jun 2, 2013 | 08:39 AM
71mopar's Avatar
Intrepid fuel line pics
Here are some pics of the line I'm talking about.Need help with where this fuel hose connects-dscn0961.jpg
Old Jun 2, 2013 | 08:50 AM
mr340's Avatar
That looks like a vacuum or vapor line, where is is attached to on the other end?
Old Jun 2, 2013 | 08:54 AM
71mopar's Avatar
fuel line
I think its a return vapor line. It runs all the way back to the tank along side the high pressure fuel line. When I was pulling the high pressure line down to change I pulled this off by mistake and now can't find where it goes to. The high pressure has a green clip this one has a blue clip.
Old Jun 2, 2013 | 09:04 AM
mr340's Avatar
Vacuum canister line?
Old Jun 2, 2013 | 09:06 AM
mr340's Avatar
diagram:
Old Jun 2, 2013 | 09:14 AM
71mopar's Avatar
fuel line
It comes up the back of the engine from the tank. It has a blue clipped disconnect which changes to a hose approx 11" long with a metal nipple end.
71beeper
Jul 2, 2014 05:53 PM
olibass1
Apr 4, 2012 11:06 AM
jar84203
Jun 15, 2010 09:39 AM
Dust'em
Apr 10, 2009 03:45 PM
burnsy26
Oct 1, 2007 01:35 PM
