01 neon rt just dies yet runs like a champ...
Old Sep 18, 2013 | 10:24 AM
ruckusracer15's Avatar
I've looked a little thru this forum but haven't found the same problem i am having... I just picked up a 01 neon rt manual trans new motor and clutch...the car will run perfectly fine,start right up,rev perfectly but as soon as the car starts to roll it will die... Either trying to take off in gear or if you get out and push the car with nobody in it ..if the wheels start to turn it will die.. Any help is appreciated
Old Sep 18, 2013 | 09:56 PM
slade's Avatar
this interesting lol jack it up and spin the wheels see if it dies
Old Sep 19, 2013 | 05:26 AM
Strange ! I would check engine movement , maybe it is pulling on wires ??? Make sure the computer ground connections are tight
Old Sep 19, 2013 | 08:10 AM
That's the first thing ill be doing when i get it to the house only paid 750 for the car its gotta be something stupid
Old Sep 19, 2013 | 08:13 AM
I've looked at most of the wiring when i got the car i haven't brought it home yet but everything looks fine engine move much...hell it can be idling and it'll die when u push it ...weird sh*t
Old Sep 19, 2013 | 03:14 PM
pro-tech's Avatar
Unhook the VSS and see what happens..It is the only link to the computer with movement... Check to make sure there are no wires rubbing on the axles causing a short to ground...Bill
Skwerly
17
Mar 22, 2013 02:35 PM
MReeves
Pro-Stock
Nov 13, 2012 05:21 AM
Tom Wright
Mar 2, 2011 03:12 PM
Monacoman
Sep 21, 2008 04:15 AM
nicolette
Dec 19, 2007 12:13 PM
