NHRA Lucas Oil Nats Brainard
Fri, 19 Aug 2011, 04:22 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
BRAINERD, Minn. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 30th annual Lucas Oil NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Paul Pittman Runs 6.820/203.37, Now #1
Right Lane: Mark Martino Runs 6.845/204.57, Now #2
Pittman is making his Pro Stock debut making the move up from Competition Eliminator. Pittman with a real nice first pass and then the chutes didn't come out. There is a long shut off area, so he has no problems. Paul Pittman's incremental times: 60ft-1.029 sec., 330ft-2.878, 660ft-4.400/162.14 mph, 1,000ft-5.712. Martino was straight down the groove. Mark Martino's incremental times: 60ft-1.002 sec., 330ft-2.897, 660ft-4.433/161.61 mph, 1,000ft-5.744.
Left Lane: Mark Hogan Runs 6.776/204.48, Now #2
Right Lane: Warren Johnson Runs 6.652/207.43, Now #1
Hogan with a good pass to start the weekend...Mark Hogan's incremental times: 60ft-1.005 sec., 330ft-2.847, 660ft-4.369/162.39 mph, 1,000ft-5.676. WJ with a great pass, Warren Johnson's incremental times: 60ft-0.987 sec., 330ft-2.784, 660ft-4.280/165.03 mph, 1,000ft-5.568.
Left Lane: Kurt Johnson Runs 14.171/72.48, Now #6
Right Lane: V. Gaines Runs 6.665/208.30, Now #2
Johnson makes a quick move toward the centerline and clicks it off. Gaines with a real nice pass to start the weekend. V. Gaines' incremental times: 60ft-1.006 sec., 330ft-2.810, 660ft-4.303/165.58 mph, 1,000ft-5.586.
Left Lane: Ronnie Humphrey Runs 8.464/109.32, Now #7
Right Lane: Larry Morgan Runs 6.661/207.18, Now #2
Humphrey with problems and pushes in the clutch early....Morgan with a real nice pas to start the weekend. Larry Morgan's incremental times: 60ft-0.996 sec., 330ft-2.795, 660ft-4.289/165.09 mph, 1,000ft-5.576.
Left Lane: Ron Krisher Runs 6.631/208.20, Now #1
Right Lane: Shane Gray Runs 6.632/207.34, Now #2
This was a good drag race as these two go to the number one a two spots. Ron Krisher's incremental times: 60ft-0.991 sec., 330ft-2.782, 660ft-4.270/165.88 mph, 1,000ft-5.551.
Shane Gray's incremental times: 60ft-0.988 sec., 330ft-2.777, 660ft-4.267/165.36 mph, 1,000ft-5.550.
Left Lane: Greg Stanfield Runs 6.660/207.62, Now #5
Right Lane: Rodger Brogdon Runs 6.632/207.69, Now #2
Brogdon with a great pass to go to the number two spot. Rodger Brogdon's incremental times: 60ft-0.986 sec., 330ft-2.778, 660ft-4.268/165.48 mph, 1,000ft-5.551. Stanfield with a good pass to start the weekend into the top half of the show. Greg Stanfield's incremental times: 60ft-0.998 sec., 330ft-2.794, 660ft-4.289/165.19 mph, 1,000ft-5.575.
Left Lane: Allen Johnson Runs 6.617/209.17, Now #1
Right Lane: Erica Enders Runs 6.628/207.34, Now #2
This was a great side-by-side drag race with these two going to the top of the list. Allen Johnson's incremental times: 60ft-0.989 sec., 330ft-2.778, 660ft-4.265/165.94 mph, 1,000ft-5.542.
Erica Enders' incremental times: 60ft-0.989 sec., 330ft-2.777, 660ft-4.266/165.76 mph, 1,000ft-5.548.
Left Lane: Vincent Nobile Runs 6.637/208.65, Now #7
Right Lane: Mike Edwards Runs 6.620/208.65, Now #2
Edwards with a real nice pass to go to the number two spot. Mike Edwards' incremental times: 60ft-0.974 sec., 330ft-2.771, 660ft-4.261/165.78 mph, 1,000ft-5.542. Nobile with a good clean pass...Vincent Nobile's incremental times: 60ft-0.990 sec., 330ft-2.785, 660ft-4.276/165.72 mph, 1,000ft-5.558.
Left Lane: Greg Anderson Runs 6.607/208.46, Now #2
Right Lane: Jason Line Runs 6.607/208.62, Now #1
The teammates here and they run identical E.T.s for number one and two. Line gets the number two spot based on his faster mph. Greg Anderson's incremental times: 60ft-0.981 sec., 330ft-2.765, 660ft-4.249/166.25 mph, 1,000ft-5.528.
Jason Line's incremental times: 60ft-0.975 sec., 330ft-2.765, 660ft-4.250/166.19 mph, 1,000ft-5.529.
Timing data courtesy of CompuLink
From DragRaceCentral.com
By Rick Green
Round 2 Qualifying
Fri, 19 Aug 2011, 07:08 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
BRAINERD, Minn. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 30th annual Lucas Oil NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Mark Martino Runs 6.700/206.35, Now #15; Best prior run: 6.845/204.57, Was #16
Right Lane: Kurt Johnson Runs 6.655/206.92, Now #11; Best prior run: 14.171/72.48, Was #18
Johnson with a good pass to get in the show for now. Kurt Johnson's incremental times: 60ft-0.991 sec., 330ft-2.783, 660ft-4.280/164.31 mph, 1,000ft-5.569. Martino improves on his earlier run. Mark Martino's incremental times: 60ft-0.996 sec., 330ft-2.807, 660ft-4.313/163.81 mph, 1,000ft-5.609.
Left Lane: V. Gaines Runs 6.624/208.75, Now #5; Best prior run: 6.665/208.30, Was #14
Right Lane: Ronnie Humphrey Runs 6.628/207.69, Now #6; Best prior run: 8.464/109.32, Was #18
Humphrey with a real good pass to get into the top half of the show. Ronnie Humphrey's incremental times: 60ft-0.994 sec., 330ft-2.780, 660ft-4.267/165.62 mph, 1,000ft-5.547. Gaines is straight down the groove to go to the number five spot. V. Gaines' incremental times: 60ft-0.993 sec., 330ft-2.779, 660ft-4.265/165.86 mph, 1,000ft-5.546.
Left Lane: Larry Morgan Runs 6.630/207.50, Now #8; Best prior run: 6.661/207.18, Was #15
Right Lane: Paul Pittman Runs 15.490/54.71, Now #18; Best prior run: 6.820/203.37, Was #18
Pittman shook and shut off...Morgan with a real nice pass to get in the show. Larry Morgan's incremental times: 60ft-0.982 sec., 330ft-2.770, 660ft-4.260/165.50 mph, 1,000ft-5.546.
Left Lane: Warren Johnson Runs 6.628/207.82, Now #6; Best prior run: 6.652/207.43, Was #13
Right Lane: Mark Hogan Runs 6.740/205.04, Now #17; Best prior run: 6.776/204.48, Was #17
Hogan improves, but not enough to get in the show. Johnson with a really nice pass to get into the top half of the show. Warren Johnson's incremental times: 60ft-0.979 sec., 330ft-2.769, 660ft-4.260/165.40 mph, 1,000ft-5.546.
Left Lane: Shane Gray Runs 6.629/207.98, Now #9; Best prior run: 6.632/207.34, Was #12
Right Lane: Greg Stanfield Runs 6.631/207.85, Now #12; Best prior run: 6.660/207.62, Was #15
Gray gets off the bump...Shane Gray's incremental times: 60ft-0.988 sec., 330ft-2.776, 660ft-4.265/165.76 mph, 1,000ft-5.548. Stanfield gets into the show...Greg Stanfield's incremental times: 60ft-0.984 sec., 330ft-2.773, 660ft-4.264/165.68 mph, 1,000ft-5.549.
Left Lane: Rodger Brogdon Runs 6.625/207.34, Now #7; Best prior run: 6.632/207.69, Was #13
Right Lane: Vincent Nobile Runs 6.612/208.39, Now #3; Best prior run: 6.637/208.65, Was #14
Nobile with the quickest pass of the session to go to the number three spot. Vincent Nobile's incremental times: 60ft-0.975 sec., 330ft-2.763, 660ft-4.252/165.66 mph, 1,000ft-5.534. Brogdon gets back into the show. Rodger Brogdon's incremental times: 60ft-0.985 sec., 330ft-2.770, 660ft-4.258/165.84 mph, 1,000ft-5.542.
Left Lane: Erica Enders Runs 8.971/104.66, Now #10; Best prior run: 6.628/207.34, Was #10
Right Lane: Ron Krisher Runs 7.443/139.34, Now #13; Best prior run: 6.631/208.20, Was #13
Enders spun early and pushed in the clutch early...Krisher had problems just before half track and he too pushed in the clutch.
Left Lane: Mike Edwards Runs 6.595/208.55, Now #1; Best prior run: 6.620/208.65, Was #5
Right Lane: Allen Johnson Runs 13.902/61.56, Now #5; Best prior run: 6.617/209.17, Was #4
Edwards launched hard and keep it hooked up to go to the number one spot. Mike Edwards' incremental times: 60ft-0.971 sec., 330ft-2.752, 660ft-4.238/166.03 mph, 1,000ft-5.517. Johnson with problems early and pushed in the clutch by 300 feet.
Left Lane: Jason Line Runs 6.600/209.23, Now #3; Best prior run: 6.607/208.62, Was #2
Right Lane: Greg Anderson Runs 6.597/208.84, Now #2; Best prior run: 6.607/208.46, Was #3
Anderson with a great pass to go to the number two spot. Greg Anderson's incremental times: 60ft-0.981 sec., 330ft-2.759, 660ft-4.242/166.27 mph, 1,000ft-5.521.
Line with the third quickest pass of the session. Jason Line's incremental times: 60ft-0.981 sec., 330ft-2.762, 660ft-4.244/166.42 mph, 1,000ft-5.523.
By Rick Green
Round 3 Qualifying
Sat, 20 Aug 2011, 12:40 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
BRAINERD, Minn. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 30th annual Lucas Oil NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Paul Pittman Runs 7.190/170.60, Now #13; No Prior Run
Right Lane: Erica Enders Runs 6.615/208.88, Now #5; Best prior run: 6.628/207.34, Was #10
Pittman with a little wiggle in the middle of the run...Enders Enders with her best pass of the weekend to move into the top half of the show. Erica Enders' incremental times: 60ft-0.983 sec., 330ft-2.769, 660ft-4.257/165.86 mph, 1,000ft-5.538.
Left Lane: Allen Johnson Runs 6.622/209.23, Now #6; Best prior run: 6.617/209.17, Was #6
Right Lane: Mark Martino Runs 6.683/206.23, Now #13; No Prior Run
Weather conditions: air temperature 70 degrees, relative humidity 58 percent, barometer 28.72 inches, adjusted altitude 2,719 feet.
Johnson with a good run, but doesn't improve on his pass from yesterday. Allen Johnson's incremental times: 60ft-0.999 sec., 330ft-2.783, 660ft-4.267/166.29 mph, 1,000ft-5.546. Martino with a good pass to get a number on the board. Mark Martino's incremental times: 60ft-0.981 sec., 330ft-2.790, 660ft-4.297/163.77 mph, 1,000ft-5.592.
Left Lane: Ron Krisher Runs 6.616/208.39, Now #6; No Prior Run
Right Lane: Larry Morgan Runs 6.629/208.10, Now #12; Best prior run: 6.630/207.50, Was #12
Morgan with his quickest pass of the weekend, but will stay in the number 12 spot. Larry Morgan's incremental times: 60ft-0.988 sec., 330ft-2.776, 660ft-4.264/165.44 mph, 1,000ft-5.548. Krisher with his quickest pass this weekend and the second quickest of the round. He gets into the top half of the show. Ron Krisher's incremental times: 60ft-0.984 sec., 330ft-2.768, 660ft-4.256/165.92 mph, 1,000ft-5.537.
Left Lane: Mark Hogan Runs 6.713/205.76, Now #15; No Prior Run
Right Lane: Shane Gray Runs 6.633/207.85, Now #13; Best prior run: 6.629/207.98, Was #13
Gray with another good pass, but he didn't improve...Shane Gray's incremental times: 60ft-0.986 sec., 330ft-2.776, 660ft-4.267/165.52 mph, 1,000ft-5.551. Hogan with his quickest pass this season to get into the show. Mark Hogan's incremental times: 60ft-0.997 sec., 330ft-2.808, 660ft-4.318/163.49 mph, 1,000ft-5.618.
Left Lane: Kurt Johnson Runs 6.631/208.26, Now #14; No Prior Run
Right Lane: Warren Johnson Runs 6.632/208.36, Now #10; Best prior run: 6.628/207.82, Was #10
No help here for WJ and he will stay in the number 10 spot. Warren Johnson's incremental times: 60ft-0.983 sec., 330ft-2.774, 660ft-4.267/165.33 mph, 1,000ft-5.552. Johnson with his quickest pass of the weekend and he will get into the show. Kurt Johnson's incremental times: 60ft-0.997 sec., 330ft-2.779, 660ft-4.268/165.60 mph, 1,000ft-5.550.
Left Lane: Greg Stanfield Runs 13.694/61.38, Now #18; No Prior Run
Right Lane: Rodger Brogdon Runs 6.598/208.33, Now #3; Best prior run: 6.625/207.34, Was #9
Stanfield with problems and pushes in the clutch early...Brogdon launched hard and keeps it hooked up to go to the number three spot with the quickest pass of the day. Rodger Brogdon's incremental times: 60ft-0.975 sec., 330ft-2.753, 660ft-4.238/165.78 mph, 1,000ft-5.519.
Left Lane: Ronnie Humphrey Runs 6.638/207.91, Now #11; Best prior run: 6.628/207.69, Was #11
Right Lane: V. Gaines Runs 6.638/208.23, Now #9; Best prior run: 6.624/208.75, Was #9
These two are side-by-side all the way down the track and run identical E.T.s...Ronnie Humphrey's incremental times: 60ft-0.987 sec., 330ft-2.780, 660ft-4.271/165.44 mph, 1,000ft-5.556.
V. Gaines' incremental times: 60ft-0.993 sec., 330ft-2.784, 660ft-4.275/165.50 mph, 1,000ft-5.558.
Left Lane: Vincent Nobile Runs 6.625/208.97, Now #5; Best prior run: 6.612/208.39, Was #5
Right Lane: Jason Line Runs 6.581/209.26, Now #1; Best prior run: 6.600/209.23, Was #4
Nobile with another good pass, but he doesn't improve...Vincent Nobile's incremental times: 60ft-0.989 sec., 330ft-2.778, 660ft-4.267/165.68 mph, 1,000ft-5.547. Line with a great pass the quickest and fastest pass of the weekend for both ends of the track record. Jason Line's incremental times: 60ft-0.971 sec., 330ft-2.747, 660ft-4.228/166.50 mph, 1,000ft-5.505.
Left Lane: Greg Anderson Runs 6.591/209.59, Now #2; Best prior run: 6.597/208.84, Was #3
Right Lane: Mike Edwards Runs 6.591/208.75, Now #3; Best prior run: 6.595/208.55, Was #2
These two are side-by-side all the way down the track and Anderson will get the edge base on the faster speed. Anderson with the fastest pass of the weekend and now he has the track speed record. Greg Anderson's incremental times: 60ft-0.979 sec., 330ft-2.757, 660ft-4.239/166.58 mph, 1,000ft-5.515.
Mike Edwards' incremental times: 60ft-0.961 sec., 330ft-2.744, 660ft-4.232/165.58 mph, 1,000ft-5.513.
By Rick Green
Final Qualifying
Sat, 20 Aug 2011, 03:38 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
BRAINERD, Minn. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 30th annual Lucas Oil NHRA Nationals
Left Lane: Mark Martino Runs 7.429/140.71, Now #16; Best prior run: 6.683/206.23, Was #15
Right Lane: Greg Stanfield Runs 6.627/207.91, Now #10; Best prior run: 13.694/61.38, Was #18
Martino was out of the groove early and over by the centerline and then around half track had a little wiggle before he clicked it off. Stanfield with his quickest pass of the weekend to get in the show and that bumps out Hogan. Greg Stanfield's incremental times: 60ft-0.983 sec., 330ft-2.768, 660ft-4.259/165.33 mph, 1,000ft-5.544.
Left Lane: Shane Gray Runs 6.672/207.66, Now #14; Best prior run: 6.629/207.98, Was #14
Right Lane: Paul Pittman Runs 6.864/201.07, Now #18; Best prior run: 7.190/170.60, Was #18
Gray with a good pass, but will not improve and will stay in the number 14 spot. Pittman with a nice clean pass, but will not get in the show...
Left Lane: Larry Morgan Runs 6.669/206.01, Now #13; Best prior run: 6.629/208.10, Was #13
Right Lane: Mark Hogan Runs 6.751/204.29, Now #17; Best prior run: 6.713/205.76, Was #17
Hogan will not improve and he will not get back in the show. Morgan with a nice pass, but he doesn't improve and will stay in the number 13 spot.
Left Lane: Warren Johnson Runs 6.644/207.91, Now #12; Best prior run: 6.628/207.82, Was #11
Right Lane: Kurt Johnson Runs 6.609/208.23, Now #5; Best prior run: 6.631/208.26, Was #15
No help here for Warren...Kurt launched hard and was straight down the groove to get into the top half of the show. the quickest pass of the round so far...Kurt Johnson's incremental times: 60ft-0.974 sec., 330ft-2.756, 660ft-4.245/165.44 mph, 1,000ft-5.528.
Left Lane: V. Gaines Runs 8.047/112.77, Now #11; Best prior run: 6.624/208.75, Was #10
Right Lane: Ronnie Humphrey Runs 6.623/207.98, Now #10; Best prior run: 6.628/207.69, Was #13
Gaines shook and clicked it off...Humphrey with his quickest pass this weekend and he moves into the number ten spot. Ronnie Humphrey's incremental times: 60ft-0.979 sec., 330ft-2.764, 660ft-4.255/165.23 mph, 1,000ft-5.541.
Left Lane: Erica Enders Runs 6.618/208.20, Now #8; Best prior run: 6.615/208.88, Was #7
Right Lane: Allen Johnson Runs 6.614/208.91, Now #7; Best prior run: 6.617/209.17, Was #9
Enders with another good pass, but Johnson bumps her back one spot. Erica Enders' incremental times: 60ft-0.976 sec., 330ft-2.760, 660ft-4.250/165.58 mph, 1,000ft-5.535.
Johnson with his quickest pass of the weekend to move into the top half of the show. Allen Johnson's incremental times: 60ft-0.989 sec., 330ft-2.771, 660ft-4.256/166.05 mph, 1,000ft-5.536.
Left Lane: Rodger Brogdon Runs 6.633/207.98, Now #4; Best prior run: 6.598/208.33, Was #4
Right Lane: Ron Krisher Runs 6.624/207.62, Now #9; Best prior run: 6.616/208.39, Was #9
Krisher with another good pass, but he will not improve and will race Enders in round one. Ron Krisher's incremental times: 60ft-0.976 sec., 330ft-2.764, 660ft-4.255/165.19 mph, 1,000ft-5.541. Brogdon with a good pass, but he will not improve...Rodger Brogdon's incremental times: 60ft-0.997 sec., 330ft-2.780, 660ft-4.267/165.78 mph, 1,000ft-5.552.
Left Lane: Mike Edwards Runs 6.622/207.98, Now #3; Best prior run: 6.591/208.75, Was #3
Right Lane: Vincent Nobile Runs 6.616/208.07, Now #6; Best prior run: 6.612/208.39, Was #6
Edwards with a good pass, but he will not improve. Mike Edwards' incremental times: 60ft-0.983 sec., 330ft-2.769, 660ft-4.257/165.76 mph, 1,000ft-5.541. Nobile with the third quickest pass of the session, but he will stay in the number six spot. Vincent Nobile's incremental times: 60ft-0.978 sec., 330ft-2.762, 660ft-4.252/165.54 mph, 1,000ft-5.536.
Left Lane: Jason Line Runs 6.595/208.91, Now #1; Best prior run: 6.581/209.26, Was #1
Right Lane: Greg Anderson Runs 6.609/208.46, Now #2; Best prior run: 6.591/209.59, Was #2
Line with the quickest pass of the round and he will qualify No. 1 for the 20th time in his career and third time this year. Jason Line's incremental times: 60ft-0.976 sec., 330ft-2.754, 660ft-4.237/166.13 mph, 1,000ft-5.516. Anderson ties Kurt Johnson for the second quickest pass of the session, but gets the pass because of his faster speed. Greg Anderson's incremental times: 60ft-0.987 sec., 330ft-2.763, 660ft-4.248/165.97 mph, 1,000ft-5.529.
By Rick Green
Summary of Eliminations
Sun, 21 Aug 2011, 05:52 PM
Summary of Eliminations in Pro Stock
BRAINERD, Minn. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 30th annual Lucas Oil NHRA Nationals:
Round 1:
Erica Enders, New Orleans LA, '10 Cobalt, Right lane, (0.023) 6.660 192.44 def. Ron Krisher, Warren OH, '09 GXP, (-0.015 foul)15.467 53.67
Allen Johnson, Greeneville TN, '11 Avenger, Right lane, (0.037) 6.618 208.94 def. Ronnie Humphrey, Jacksonville NC, '09 GXP, (0.199)6.643 207.21
Rodger Brogdon, Tomball TX, '09 GXP, Right lane, (0.032) 6.622 208.10 def. Warren Johnson, Sugar Hill GA, '09 GXP, (0.029) 6.638207.82
Greg Anderson, Mooresville NC, '09 GXP, Right lane, (0.028) 6.592 209.01 def. Shane Gray, Denver NC, '09 GXP, (-0.007 foul) 6.645208.20
Mike Edwards, Coweta OK, '09 GXP, Right lane, (0.050) 6.610 208.39 def. Larry Morgan, Newark OH, '11 Mustang, (0.092) 6.618 208.14
Jason Line, Mooresville NC, '09 GXP, Right lane, (0.052) 6.580 208.97 def. Mark Martino, Stoney Creek ON, '09 GXP, (0.055) 6.706206.13
Greg Stanfield, Bossier City LA, '09 GXP, Left lane, (0.032) 6.623 207.98 def. Kurt Johnson, Sugar Hill GA, '09 GXP, (0.074) 6.608208.81
Vincent Nobile, Dix Hills NY, '11 Avenger, Right lane, (0.014) 6.615 208.62 def. V. Gaines, Lakewood CO, '11 Avenger, (0.052) 11.93973.12
Round 2:
R Brogdon, Right lane, (0.054) 6.596 208.10 def. G Stanfield, (0.038) 6.624 208.04
V Nobile, Left lane, (0.017) 6.624 208.84 def. M Edwards, (-0.002 foul) 6.603 208.75
G Anderson, Right lane, (0.031) 6.580 209.33 def. A Johnson, (0.021) 6.611 209.43
E Enders, Left lane, (0.026) 6.622 207.91 def. J Line, (0.057) 6.591 209.04
Round 3:
E Enders, Left lane, (0.013) 6.613 207.78 def. R Brogdon, (0.027) 14.761 57.24
G Anderson, Left lane, (0.036) 6.600 208.68 def. V Nobile, (0.023) 6.640 207.85
Round 4:
G Anderson, Right lane, (0.031) 6.599 209.26 def. E Enders, (0.027) 6.614 208.10
Low ET: Jason Line 6.580 seconds
Top Speed: Greg Anderson 209.59 MPH
Round 1:
Round 2:
Round 3:
Round 4:
