NHRA Southern Nationals Atlanta
Old May 13, 2011 | 05:33 PM
Fri, 13 May 2011, 05:08 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
COMMERCE, Ga. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 31st annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Steve Spiess Runs 6.777/204.20, Now #1
Right Lane: Mark Martino Runs 15.609/53.35, Now #2
Weather conditions: air temperature 88 degrees, relative humidity 40 percent, barometer 28.98 inches, adjusted altitude 3,678 feet, track temperature 117 degrees.
Martino with problems early and he pushes the clutch on early. Steve Spiess' incremental times: 60ft-1.002 sec., 330ft-2.839, 660ft-4.362/162.04 mph, 1,000ft-5.672.
Left Lane: Robert Patrick Runs 6.808/204.48, Now #3
Right Lane: Steve Kent Runs 6.737/204.66, Now #1
Robert Patrick's incremental times: 60ft-1.025 sec., 330ft-2.866, 660ft-4.391/161.92 mph, 1,000ft-5.704.
Steve Kent's incremental times: 60ft-1.007 sec., 330ft-2.831, 660ft-4.341/164.03 mph, 1,000ft-5.640.
Left Lane: Buddy Perkinson Runs 6.802/204.60, Now #4
Right Lane: Warren Johnson Runs 6.780/204.88, Now #3
This is WJ's 600th National event. Buddy Perkinson's incremental times: 60ft-1.020 sec., 330ft-2.865, 660ft-4.389/161.81 mph, 1,000ft-5.699.
Warren Johnson's incremental times: 60ft-1.023 sec., 330ft-2.853, 660ft-4.373/163.26 mph, 1,000ft-5.679.
Left Lane: Larry Morgan Runs 6.741/206.67, Now #3
Right Lane: V. Gaines Runs 6.692/207.53, Now #1
A couple good looking passes...Larry Morgan's incremental times: 60ft-1.034 sec., 330ft-2.849, 660ft-4.353/163.93 mph, 1,000ft-5.648.
V. Gaines' incremental times: 60ft-1.003 sec., 330ft-2.812, 660ft-4.314/165.23 mph, 1,000ft-5.605.
Left Lane: Kurt Johnson Runs 6.698/206.35, Now #2
Right Lane: Shane Gray Runs 6.733/205.07, Now #3
Gray with a good short time, the quickest of the session...Kurt Johnson's incremental times: 60ft-0.993 sec., 330ft-2.797, 660ft-4.305/163.43 mph, 1,000ft-5.604.
Shane Gray's incremental times: 60ft-0.981 sec., 330ft-2.802, 660ft-4.323/162.98 mph, 1,000ft-5.631.
Left Lane: Ron Krisher Runs 6.667/207.88, Now #2
Right Lane: Allen Johnson Runs 6.653/207.78, Now #1
This was a good looking drag race as they were side-by-side all the way down the track. Ron Krisher's incremental times: 60ft-0.986 sec., 330ft-2.791, 660ft-4.290/164.85 mph, 1,000ft-5.580.
Allen Johnson's incremental times: 60ft-0.985 sec., 330ft-2.777, 660ft-4.276/165.31 mph, 1,000ft-5.566.
Left Lane: Rodger Brogdon Runs 6.652/207.21, Now #1
Right Lane: Erica Enders Runs 6.676/206.83, Now #4
Another good drag race and Brogdon goes to the number one spot. Rodger Brogdon's incremental times: 60ft-0.986 sec., 330ft-2.775, 660ft-4.272/164.67 mph, 1,000ft-5.563. Enders with a real nice pass to go to the number four spot. Erica Enders' incremental times: 60ft-0.994 sec., 330ft-2.793, 660ft-4.293/165.01 mph, 1,000ft-5.586.
Left Lane: Vincent Nobile Runs 6.671/207.24, Now #5
Right Lane: Mike Edwards Runs 6.641/207.56, Now #1
Edwards with the quickest 60-foot time and parlays that into the number one spot. Mike Edwards' incremental times: 60ft-0.973 sec., 330ft-2.771, 660ft-4.267/165.74 mph, 1,000ft-5.555. Nobile coming off his win two weeks ago in Houston with a real nice pass to get into the top half of the show. Vincent Nobile's incremental times: 60ft-0.982 sec., 330ft-2.783, 660ft-4.287/164.15 mph, 1,000ft-5.581.
Left Lane: Greg Stanfield Runs 6.689/206.23, Now #7
Right Lane: Greg Anderson 18.247/43.20, Now #18
Anderson with problems as soon as he let the clutch out and pushed it right back in. Stanfield with a good pass to get in the field. Greg Stanfield's incremental times: 60ft-0.991 sec., 330ft-2.792, 660ft-4.297/163.91 mph, 1,000ft-5.594.
Right Lane: Jason Line Runs 6.642/207.30, Now #2
Line with a real nice pass to go to the number two spot. Jason Line's incremental times: 60ft-0.984 sec., 330ft-2.777, 660ft-4.270/165.68 mph, 1,000ft-5.556.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old May 13, 2011 | 05:35 PM
Round 2 Qualifying
Fri, 13 May 2011, 08:00 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
COMMERCE, Ga. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 31st annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Greg Anderson Runs 6.632/207.37, Now #1; Best prior run: 18.427/43.20, Was #19
Right Lane: Robert Patrick Runs 12.471/69.63, Now #18; Best prior run: 6.808/204.48, Was #17
Weather conditions: air temperature 77 degrees, relative humidity 58 percent, barometer 29.01 inches, adjusted altitude 2,939 feet, track temperature 94 degrees.
Patrick with problems right off the starting line and clicks it off. Anderson with a great looking pass to go to the number one spot. Greg Anderson's incremental times: 60ft-0.984 sec., 330ft-2.772, 660ft-4.264/165.29 mph, 1,000ft-5.548.
Left Lane: Mark Martino Runs 6.750/204.85, Now #15; Best prior run: 15.609/53.35, Was #19
Right Lane: Buddy Perkinson Runs 7.273/146.16, Now #18; Best prior run: 6.802/204.60, Was #17
Perkinson with problems and pushes in the clutch early. Martino makes a move in the right direction, but doesn't get in the show.
Left Lane: Warren Johnson Runs 6.658/207.21, Now #6; Best prior run: 6.780/204.88, Was #17
Right Lane: Steve Spiess Runs 12.594/68.76, Now #17; Best prior run: 6.777/204.20, Was #16
Spiess pushes in the clutch early. WJ with real nice pass to get into the top half of the field. Warren Johnson's incremental times: 60ft-0.983 sec., 330ft-2.778, 660ft-4.276/164.69 mph, 1,000ft-5.568.
Left Lane: Steve Kent Runs 9.774/91.01, Now #15; Best prior run: 6.737/204.66, Was #14
Right Lane: Larry Morgan Runs 6.678/207.02, Now #10; Best prior run: 6.741/206.67, Was #15
Kent pushes in the clutch early and coast on through the 1320. Morgan gets into the show. Larry Morgan's incremental times: 60ft-1.006 sec., 330ft-2.802, 660ft-4.300/165.27 mph, 1,000ft-5.590.
Left Lane: Shane Gray Runs 6.697/205.47, Now #13; Best prior run: 6.733/205.07, Was #14
Right Lane: Kurt Johnson Runs 6.891/174.35, Now #14; Best prior run: 6.698/206.35, Was #13
Gray makes a move in the right direction, but not enough to get in the show. Johnson gets real loose after the finish line and crosses over behind Gray.
Left Lane: V. Gaines Runs 6.662/207.62, Now #7; Best prior run: 6.692/207.53, Was #12
Right Lane: Greg Stanfield Runs 6.664/206.39, Now #8; Best prior run: 6.689/206.23, Was #11
These two were side-by-side all the way down the 1320. V. Gaines' incremental times: 60ft-0.993 sec., 330ft-2.789, 660ft-4.287/164.77 mph, 1,000ft-5.577.
Greg Stanfield's incremental times: 60ft-0.982 sec., 330ft-2.777, 660ft-4.277/164.79 mph, 1,000ft-5.572.
Left Lane: Erica Enders Runs 6.658/207.27, Now #7; Best prior run: 6.676/206.83, Was #11
Right Lane: Vincent Nobile Runs 6.653/207.15, Now #6; Best prior run: 6.671/207.24, Was #10
Another great side-by-side drag race...Erica Enders' incremental times: 60ft-0.987 sec., 330ft-2.782, 660ft-4.280/164.53 mph, 1,000ft-5.571.
Vincent Nobile's incremental times: 60ft-0.982 sec., 330ft-2.776, 660ft-4.274/165.31 mph, 1,000ft-5.565.
Left Lane: Allen Johnson Runs 6.619/208.59, Now #1; Best prior run: 6.653/207.78, Was #5
Right Lane: Ron Krisher Runs 6.631/208.14, Now #2; Best prior run: 6.667/207.88, Was #11
This was a great drag race, as these two go to the top of the list...Allen Johnson's incremental times: 60ft-0.979 sec., 330ft-2.762, 660ft-4.252/165.58 mph, 1,000ft-5.537.
Ron Krisher's incremental times: 60ft-0.980 sec., 330ft-2.771, 660ft-4.264/165.74 mph, 1,000ft-5.549.
Left Lane: Jason Line Runs 6.619/208.84, Now #1; Best prior run: 6.642/207.30, Was #5
Right Lane: Rodger Brogdon No Time, Now #6; Best prior run: 6.652/207.21, Was #6
Brogdon broke on the burnout and is pushed back to the starting line. Line was straight down Broadway to go to the number one spot. Jason Line's incremental times: 60ft-0.983 sec., 330ft-2.772, 660ft-4.260/165.82 mph, 1,000ft-5.539.
Left Lane: Mike Edwards Runs 6.605/208.55, Now #1; Best prior run: 6.641/207.56, Was #5
Edwards with the quickest 60-foot time of the round and he parlays that into a number one spot. Mike Edwards' incremental times: 60ft-0.965 sec., 330ft-2.752, 660ft-4.242/165.56 mph, 1,000ft-5.525.
Old May 14, 2011 | 02:26 PM
Round 3 Qualifying
Sat, 14 May 2011, 12:46 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
COMMERCE, Ga. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 31st annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Ronnie Humphrey Runs 6.665/207.05, Now #13; No Prior Run
Right Lane: Steve Kent Runs 6.664/205.91, Now #12; No Prior Run
Weather conditions: air temperature 76 degrees, relative humidity 63 percent, barometer 28.98 inches, adjusted altitude 3,004 feet, track temperature 101 degrees.
Humphrey making his first pass this weekend as he attended his daughter's graduation from the University of North Carolina yesterday. Both of these drivers get in the show for now.
Left Lane: Rodger Brogdon Runs 6.618/207.72, Now #2; Best prior run: 6.652/207.21, Was #6
Right Lane: Mark Martino Runs 6.714/205.91, Now #15; No Prior Run
Brogdon with a little tire spin right off the starting line and then blasted straight down the groove into the number two spot. Rodger Brogdon's incremental times: 60ft-0.980 sec., 330ft-2.760, 660ft-4.250/165.36 mph, 1,000ft-5.534. Martino with his quickest pass of the weekend...Mark Martino's incremental times: 60ft-0.999 sec., 330ft-2.813, 660ft-4.321/164.25 mph, 1,000ft-5.619.
Left Lane: Steve Spiess Runs 11.736/75.07, Now #17; No Prior Run
Right Lane: Shane Gray Runs 6.670/206.48, Now #14; No Prior Run
Spiess really spun the tires hard right off the starting line and then pushed in the clutch. Gray with his quickest pass of the weekend...Shane Gray's incremental times: 60ft-0.980 sec., 330ft-2.780, 660ft-4.282/164.61 mph, 1,000ft-5.578.
Left Lane: Robert Patrick Runs 6.702/205.60, Now #16; No Prior Run
Right Lane: V. Gaines Runs 6.671/207.46, Now #10; Best prior run: 6.662/207.62, Was #10
No help here for Gaines...Patrick with his quickest pass of the weekend to get into the show. Robert Patrick's incremental times: 60ft-0.996 sec., 330ft-2.796, 660ft-4.305/163.45 mph, 1,000ft-5.605.
Left Lane: Buddy Perkinson Runs 6.732/205.07, Now #18; No Prior Run
Right Lane: Warren Johnson Runs 6.688/206.99, Now #9; Best prior run: 6.658/207.21, Was #9
Perkinson with his quickest pass of the weekend, but he will not get into the show. No help here for Warren and he will stay in the number nine spot.
Left Lane: Kurt Johnson Runs 6.704/206.61, Now #17; No Prior Run
Right Lane: Erica Enders Runs 12.437/69.86, Now #8; Best prior run: 6.658/207.27, Was #8
Johnson slows from his best time yesterday and will not get in the show on this pass. He is down to one last pass to get in here at his home track. Enders shook and pushed in the clutch and she is not in the show.
Left Lane: Larry Morgan Runs 6.681/207.21, Now #15; Best prior run: 6.678/207.02, Was #15
Right Lane: Greg Anderson Runs 6.636/207.62, Now #6; Best prior run: 6.632/207.37, Was #6
No help here for Morgan and he will stay in the number 15 spot. Larry Morgan's incremental times: 60ft-0.998 sec., 330ft-2.803, 660ft-4.302/164.63 mph, 1,000ft-5.593. Anderson is just a tick off his pass yesterday and he will stay in the number six spot. Greg Anderson's incremental times: 60ft-0.986 sec., 330ft-2.777, 660ft-4.268/165.88 mph, 1,000ft-5.551.
Left Lane: Greg Stanfield Runs 13.752/62.14, Now #11; Best prior run: 6.664/206.39, Was #11
Right Lane: Allen Johnson Runs 6.624/208.75, Now #4; Best prior run: 6.619/208.59, Was #4
Stanfield with problems early and pushes in the clutch. Johnson with a really nice pass, second quickest of the session. Allen Johnson's incremental times: 60ft-0.981 sec., 330ft-2.768, 660ft-4.259/166.19 mph, 1,000ft-5.543.
Left Lane: Vincent Nobile Runs 6.634/208.39, Now #7; Best prior run: 6.653/207.15, Was #7
Right Lane: Jason Line Runs 6.608/207.91, Now #2; Best prior run: 6.619/208.84, Was #3
Nobile with his quickest pass of the weekend, but will stay in the number seven spot. Vincent Nobile's incremental times: 60ft-0.972 sec., 330ft-2.764, 660ft-4.261/164.89 mph, 1,000ft-5.549. Line with a great looking pass, the quickest pass of the session and he moves up the ladder one spot. Jason Line's incremental times: 60ft-0.973 sec., 330ft-2.756, 660ft-4.244/166.33 mph, 1,000ft-5.525.
Left Lane: Ron Krisher Runs 6.646/207.94, Now #5; Best prior run: 6.631/208.14, Was #5
Right Lane: Mike Edwards Runs 6.621/208.39, Now #1; Best prior run: 6.605/208.55, Was #1
Krisher with a good pass...Ron Krisher's incremental times: 60ft-0.983 sec., 330ft-2.777, 660ft-4.273/165.11 mph, 1,000ft-5.561. Edwards with the third quickest pass of the round, but holds on to the number one spot. Mike Edwards' incremental times: 60ft-0.971 sec., 330ft-2.763, 660ft-4.255/165.97 mph, 1,000ft-5.539.
Old May 14, 2011 | 02:29 PM
Round 4 Qualifying
Sat, 14 May 2011, 04:12 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
COMMERCE, Ga. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 31st annual Summit Racing Equipment NHRA Southern Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Mark Martino Runs 6.727/205.60, Now #18; Best prior run: 6.714/205.91, Was #18
Right Lane: Steve Spiess Runs 8.236/119.19, Now #20; Best prior run: 11.736/75.07, Was #20
Weather conditions: air temperature 78 degrees, relative humidity 58 percent, barometer 28.90 inches, adjusted altitude 3,183 feet, track temperature 116 degrees.
Spiess with problems early in the run and pushes in the clutch. Martino slows from his earlier pass today and he will not get in the show
Left Lane: Shane Gray Runs 6.686/205.98, Now #14; Best prior run: 6.670/206.48, Was #14
Right Lane: Buddy Perkinson Runs 6.728/205.13, Now #19; Best prior run: 6.732/205.07, Was #19
Gray with another nice pass, but will not improve. Shane Gray's incremental times: 60ft-0.981 sec., 330ft-2.787, 660ft-4.293/163.81 mph, 1,000ft-5.591. Perkinson with his quickest pass of the weekend, but not quick enough to get in the show. Buddy Perkinson's incremental times: 60ft-1.001 sec., 330ft-2.813, 660ft-4.326/163.31 mph, 1,000ft-5.629.
Left Lane: Steve Kent Runs 6.649/207.05, Now #8; Best prior run: 6.664/205.91, Was #12
Right Lane: Kurt Johnson Runs 6.724/205.35, Now #17; Best prior run: 6.704/206.61, Was #17
Kent with a little bit of problem on the burnout, his crew has to push him back to the starting line. Kent with his quickest pass of the weekend and he moves up into the top half of the show. Steve Kent's incremental times: 60ft-0.983 sec., 330ft-2.773, 660ft-4.269/164.59 mph, 1,000ft-5.560. Johnson will not improve on his earlier run today and he will not qualify.
Left Lane: V. Gaines Runs 6.655/207.53, Now #9; Best prior run: 6.662/207.62, Was #11
Right Lane: Robert Patrick Runs 6.700/205.60, Now #16; Best prior run: 6.702/205.60, Was #16
Patrick will race on Sunday and now runs his quickest pass of the weekend, but will not move off the bubble. Robert Patrick's incremental times: 60ft-0.998 sec., 330ft-2.797, 660ft-4.303/164.51 mph, 1,000ft-5.603. Gaines with his quickest pass of weekend, and he moves up the ladder a couple spots. V. Gaines' incremental times: 60ft-0.988 sec., 330ft-2.781, 660ft-4.277/164.95 mph, 1,000ft-5.568.
Left Lane: Warren Johnson Runs 6.666/207.40, Now #11; Best prior run: 6.658/207.21, Was #11
Right Lane: Larry Morgan Runs 6.659/206.80, Now #12; Best prior run: 6.678/207.02, Was #15
Johnson with a nice pass, but will not improve and will stay 11th. Warren Johnson's incremental times: 60ft-0.983 sec., 330ft-2.782, 660ft-4.282/164.45 mph, 1,000ft-5.577. Morgan with his quickest pass of the weekend to move up three spots on the ladder. Larry Morgan's incremental times: 60ft-0.986 sec., 330ft-2.779, 660ft-4.276/165.33 mph, 1,000ft-5.568.
Left Lane: Erica Enders Runs 6.637/208.01, Now #8; Best prior run: 6.658/207.27, Was #10
Right Lane: Ronnie Humphrey Runs 6.655/207.27, Now #11; Best prior run: 6.665/207.05, Was #14
Enders with her quickest pass of the weekend to move into the top half of the show. Erica Enders' incremental times: 60ft-0.986 sec., 330ft-2.773, 660ft-4.265/165.23 mph, 1,000ft-5.552. Ronnie Humphrey with only his second pass this weekend and he improves to move up to the number 11 spot. Ronnie Humphrey's incremental times: 60ft-0.986 sec., 330ft-2.782, 660ft-4.279/165.40 mph, 1,000ft-5.568.
Left Lane: Greg Anderson Runs 6.626/207.30, Now #5; Best prior run: 6.632/207.37, Was #6
Right Lane: Greg Stanfield Runs 6.661/206.51, Now #14; Best prior run: 6.664/206.39, Was #14
Stanfield with his quickest pass of the weekend, but will stay in the number 14 spot. Greg Stanfield's incremental times: 60ft-0.983 sec., 330ft-2.777, 660ft-4.276/165.29 mph, 1,000ft-5.569. Anderson with his quickest pass of the weekend and he moves up the ladder one spot. Greg Anderson's incremental times: 60ft-0.980 sec., 330ft-2.764, 660ft-4.254/165.44 mph, 1,000ft-5.539.
Left Lane: Allen Johnson Runs 6.611/208.78, Now #3; Best prior run: 6.619/208.59, Was #4
Right Lane: Vincent Nobile Runs 6.667/207.46, Now #7; Best prior run: 6.634/208.39, Was #7
Nobile with a nice pass, but doesn't improve...Vincent Nobile's incremental times: 60ft-0.989 sec., 330ft-2.788, 660ft-4.289/164.87 mph, 1,000ft-5.580. Johnson with his quickest pass of the weekend to move up the ladder one spot. Allen Johnson's incremental times: 60ft-0.976 sec., 330ft-2.757, 660ft-4.246/165.68 mph, 1,000ft-5.529.
Left Lane: Jason Line Runs 6.623/207.94, Now #2; Best prior run: 6.608/207.91, Was #2
Right Lane: Ron Krisher Runs 6.665/206.83, Now #6; Best prior run: 6.631/208.14, Was #6
Krisher with a good pass, but will not improve. Ron Krisher's incremental times: 60ft-0.994 sec., 330ft-2.791, 660ft-4.289/165.21 mph, 1,000ft-5.578. Line with the second quickest pass of the session...Jason Line's incremental times: 60ft-0.981 sec., 330ft-2.765, 660ft-4.255/165.40 mph, 1,000ft-5.539.
Left Lane: Mike Edwards Runs 6.623/208.23, Now #1; Best prior run: 6.605/208.55, Was #1
Right Lane: Rodger Brogdon Runs 6.637/207.66, Now #4; Best prior run: 6.618/207.72, Was #4
Edwards with the second quickest pass of the session...Mike Edwards' incremental times: 60ft-0.975 sec., 330ft-2.767, 660ft-4.258/165.64 mph, 1,000ft-5.542. Brogdon with another good looking pass. Rodger Brogdon's incremental times: 60ft-0.986 sec., 330ft-2.773, 660ft-4.263/165.74 mph, 1,000ft-5.551.
Old May 16, 2011 | 04:50 PM
Summary of Eliminations
Sun, 15 May 2011, 06:42 PM
Summary of Eliminations in Pro Stock
COMMERCE, Ga. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 31st annual Summit Racing Equipment NHRA Southern Nationals:
Round 1:
Erica Enders, New Orleans LA, '10 Cobalt, Left lane, (0.038) 6.607 208.55 def. Steve Kent, LottieLA, '09 GXP, (-0.122 foul) 19.171 36.17
Vincent Nobile, Dix Hills NY, '11 Avenger, Left lane, (0.038) 6.623 208.81 def. V. Gaines, LakewoodCO, '11 Avenger, (0.050) 6.636 207.94
Ronnie Humphrey, Jacksonville NC, '09 GXP, Right lane, (0.043) 6.627 207.69 def. Ron Krisher,Warren OH, '09 GXP, (0.063) 6.627 208.42
Greg Anderson, Morresville NC, '09 GXP, Left lane, (0.039) 6.618 207.18 def. Warren Johnson, SugarHill GA, '10 Cobalt, (0.054) 6.650 207.56
Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.050) 6.611 208.14 def. Larry Morgan, Newark OH,'11 Mustang, (0.056) 6.631 207.72
Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.105) 6.605 209.04 def. Robert Patrick,Fredricksburg VA, '11 Mustang, (0.023) 6.721 204.98
Jason Line, Mooresville NC, '09 GXP, Left lane, (0.060) 6.611 207.18 def. Shane Gray, Denver NC,'09 GXP, (0.023) 6.676 207.18
Allen Johnson, Greeneville TN, '11 Avenger, Left lane, (0.025) 6.605 209.43 def. Greg Stanfield,Bossier City LA, '09 GXP, (0.023) 6.626 208.46
Round 2:
J Line, Left lane, (0.036) 6.605 208.17 def. V Nobile, (-0.001 foul) 6.666 208.42
G Anderson, Right lane, (0.014) 6.622 207.50 def. R Brogdon, (0.020) 6.625 206.99
M Edwards, Left lane, (0.037) 6.581 209.20 def. E Enders, (0.016) 6.611 208.81
A Johnson, Left lane, (0.018) 6.618 209.20 def. R Humphrey, (0.164) 9.535 96.22
Round 3:
J Line, Left lane, (0.045) 6.607 208.49 def. A Johnson, (0.015) 16.772 48.01
G Anderson, Right lane, (0.021) 6.627 207.69 def. M Edwards, (0.040) 18.949 37.00
Round 4:
J Line, Left lane, (0.034) 6.600 208.42 def. G Anderson, (0.069) 6.610 208.33
Low ET: Mike Edwards 6.581 seconds
Top Speed: Allen Johnson 209.43 MPH
MReeves
Pro-Stock
May 16, 2010 02:24 PM
MReeves
Funny Car
May 16, 2010 02:19 PM
MReeves
Super Stock
May 15, 2010 07:02 PM
MReeves
Stock Eliminator
May 15, 2010 06:45 PM
MReeves
Super Gas
May 15, 2010 08:03 AM
