NHRA Super Nationals Englishtown
Old Jun 3, 2011 | 02:50 PM
Fri, 3 Jun 2011, 04:42 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
ENGLISHTOWN, N.J. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: John Gaydosh Jr Runs 7.642/127.63, Now #2
Right Lane: Frank Gugliotta Runs 6.734/207.46, Now #1
Weather conditions: air temperature 81 degrees, relative humidity 25 percent, barometer 29.95 inches, adjusted altitude 1,850 feet, track temperature 124 degrees.
Gaydosh Jr. making his first run this season. Gaydosh Jr. was out of the groove early and got real close to the out boundry line, but keep it off it. Gugliotta with a good pass to start the weekend. Frank Gugliotta's incremental times: 60ft-1.030 sec., 330ft-2.845, 660ft-4.349/163.47 mph, 1,000ft-5.645.
Left Lane: Robert Patrick Runs 11.404/77.46, Now #4
Right Lane: Bob Benza Runs 6.717/202.52, Now #1
Patrick shook and pushed in the clutch right off the starting line. Benza with a clean pass...
Left Lane: Steve Kent Runs 7.935/122.49, Now #5
Right Lane: Kurt Johnson Runs 6.648/210.14, Now #1
Kent with problems and pushed in the clutch early. Johnson launched hard and keep it hooked up with a real nice pass. Kurt Johnson's incremental times: 60ft-1.015 sec., 330ft-2.811, 660ft-4.296/165.78 mph, 1,000ft-5.573.
Left Lane: Warren Johnson Runs 6.641/210.67, Now #1
Right Lane: Larry Morgan Runs 16.617/49.21, Now #8
Morgan shook right off the starting line and clicked it off. WJ with a great pass...Warren Johnson's incremental times: 60ft-1.012 sec., 330ft-2.811, 660ft-4.293/166.31 mph, 1,000ft-5.568.
Left Lane: V. Gaines Runs 6.989/206.54, Now #6
Right Lane: Ronnie Humphrey Runs 6.573/212.26, Now #1
Gaines made a quick move toward the centerline, but reeled it in. Humphrey launched hard and was straight down the groove with a great pass. Ronnie Humphrey's incremental times: 60ft-0.998 sec., 330ft-2.778, 660ft-4.246/167.86 mph, 1,000ft-5.509.
Left Lane: Ron Krisher Runs 6.536/212.29, Now #1
Right Lane: Shane Gray Runs 6.560/211.06, Now #2
This was a great side-by-side drag race...Ron Krisher's incremental times: 60ft-0.981 sec., 330ft-2.746, 660ft-4.213/167.84 mph, 1,000ft-5.474.
Shane Gray's incremental times: 60ft-0.982 sec., 330ft-2.750, 660ft-4.220/167.07 mph, 1,000ft-5.489. After the run Krisher's right front tire went flat and he did a great job getting the car stopped.
Left Lane: Allen Johnson Runs 6.538/211.89, Now #2
Right Lane: Erica Enders Runs 6.566/211.49, Now #4
Another really good drag race. Johnson goes to the number two spot. Allen Johnson's incremental times: 60ft-0.987 sec., 330ft-2.743, 660ft-4.209/167.57 mph, 1,000ft-5.473. Enders goes to the number four spot. Erica Enders' incremental times: 60ft-0.988 sec., 330ft-2.760, 660ft-4.231/167.38 mph, 1,000ft-5.498.
Left Lane: Vincent Nobile Runs 10.848/81.59, Now #14
Right Lane: Rodger Brogdon Runs 6.563/211.63, Now #4
nobile was real loose right off the starting line and pushed in the clutch. Brogdon was straight down the groove. Rodger Brogdon's incremental times: 60ft-0.993 sec., 330ft-2.760, 660ft-4.229/167.66 mph, 1,000ft-5.496.
Left Lane: Mike Edwards Runs 6.538/211.79, Now #3
Right Lane: Greg Stanfield Runs 6.567/210.24, Now #7
Edwards with a real nice pass and ties A. Johnson with second quickest pass of the session. He will give up the number two spot base on mph. Mike Edwards' incremental times: 60ft-0.972 sec., 330ft-2.738, 660ft-4.207/167.51 mph, 1,000ft-5.472. Stanfield with a good pass. Greg Stanfield's incremental times: 60ft-0.984 sec., 330ft-2.751, 660ft-4.224/167.12 mph, 1,000ft-5.494.
Left Lane: Greg Anderson Runs 6.548/211.26, Now #5
Right Lane: Jason Line Runs 6.533/211.93, Now #1
Line with a great pass to go to the number one spot...Jason Line's incremental times: 60ft-0.987 sec., 330ft-2.747, 660ft-4.209/168.32 mph, 1,000ft-5.469. Anderson with a good pass to open up the weekend and he goes to the number five spot. Greg Anderson's incremental times: 60ft-0.985 sec., 330ft-2.748, 660ft-4.215/167.68 mph, 1,000ft-5.480.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old Jun 3, 2011 | 05:33 PM
Round 2 Qualifying
Fri, 3 Jun 2011, 07:18 PM
Pro Stock Qualifying Notes, Session #2
By Jim Samuel
ENGLISHTOWN, N.J. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Larry Morgan Runs 13.772/62.11, Now #20; Best prior run: 16.617/49.21, Was #20
Right Lane: Robert Patrick Runs 15.998/51.59, Now #19; Best prior run: 11.404/77.46, Was #19
6:52 p.m. - Weather conditions: air temperature 77 degrees, relative humidity 27 percent, barometer 29.94 inches, adjusted altitude 1,563 feet, track temperature 97 degrees.
Morgan launched and the rear end of his car got lost. He backed off the throttle. Patrick clicked his car off right away too, after his car shook the rear tires coming off the starting line.
Left Lane: Frank Gugliotta Runs 14.309/59.39, Now #15; Best prior run: 6.734/207.46, Was #14
Right Lane: Vincent Nobile Runs 6.527/211.89, Now #1; Best prior run: 10.848/81.59, Was #18
Gugliotta's car made a move to the right as soon as he launched. Nobile moved to the top of the order with a good run right down the groove.
Left Lane: Bob Benza Runs 6.632/209.36, Now #12; Best prior run: 6.717/202.52, Was #14
Right Lane: Steve Kent Runs 8.975/104.25, Now #18; Best prior run: 7.935/122.49, Was #18
Benza made it into the top 12 for now. Kent's car was a little loose and not as quick as in the first session. Bob Benza is on the bump spot at 6.632.
Left Lane: Kurt Johnson Runs 11.760/75.17, Now #14; Best prior run: 6.648/210.14, Was #14
Right Lane: John Gaydosh Jr Runs 6.790/201.67, Now #16; Best prior run: 7.642/127.63, Was #17
Johnson launched and his car moved toward the center line. Gaydosh was not as quick as in the first session. Neither driver made the top 12. Bob Benza is on the bump spot at 6.632.
Left Lane: Ronnie Humphrey Runs 7.413/183.87, Now #12; Best prior run: 6.573/212.26, Was #11
Right Lane: V. Gaines Runs 6.571/211.20, Now #11; Best prior run: 6.989/206.54, Was #17
Gaines went down the groove to make it into the top 12. In doing so, he pushed Benza out of the top 12 and Humphrey onto the bump spot 6.573.
Left Lane: Greg Stanfield Runs 6.532/210.93, Now #2; Best prior run: 6.567/210.24, Was #10
Right Lane: Warren Johnson Runs 6.624/210.97, Now #13; Best prior run: 6.641/210.67, Was #14
Johnson car wiggled coming out of the gate. He did not make it into the top 12. Stanfield took his car down the groove and into the number two spot in the order. Ronnie Humphrey is on the bump spot at 6.573.
Left Lane: Erica Enders Runs 6.510/211.93, Now #1; Best prior run: 6.566/211.49, Was #10
Right Lane: Greg Anderson Runs 6.517/212.06, Now #2; Best prior run: 6.548/211.26, Was #7
Enders took over the top spot with a very good run. Her 60-foot time was 0.964 seconds. Anderson put himself in the number two spot in the order with his run. Ronnie Humphrey is on the bump spot at 6.573.
Left Lane: Rodger Brogdon Runs 6.511/211.66, Now #2; Best prior run: 6.563/211.63, Was #10
Right Lane: Mike Edwards Runs 13.625/50.81, Now #9; Best prior run: 6.538/211.79, Was #8
Edwards had a slow start and gave up on this run right away. Brogdon moved up eight spots with a strong pass down the track.
Left Lane: Shane Gray Runs 6.510/212.46, Now #1; Best prior run: 6.560/211.06, Was #10
Right Lane: Allen Johnson Runs 6.514/212.53, Now #4; Best prior run: 6.538/211.89, Was #8
Gray moved to the top of the order. Johnson moved up four spots.
Left Lane: Jason Line Runs 6.517/212.19, Now #5; Best prior run: 6.533/211.93, Was #8
Right Lane: Ron Krisher Runs 6.523/213.03, Now #7; Best prior run: 6.536/212.29, Was #9
Line moved up three spots, Krisher two with a pair of good runs.
Old Jun 4, 2011 | 04:57 PM
Final Qualifying
Sat, 4 Jun 2011, 03:58 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
ENGLISHTOWN, N.J. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Larry Morgan Runs 6.562/210.57, Now #14; Best prior run: 21.838/35.15, Was #19
Weather conditions: air temperature 78 degrees, relative humidity 38 percent, barometer 29.97 inches, adjusted altitude 1,737 feet, track temperature 104 degrees.
Morgan with a little wiggle right at the hit, but reeled it in to get in the show. Larry Morgan's incremental times: 60ft-0.973 sec., 330ft-2.745, 660ft-4.218/166.99 mph, 1,000ft-5.490.
Left Lane: Frank Gugliotta Runs 14.451/48.40, Now #17; Best prior run: 6.665/208.30, Was #17
Right Lane: Robert Patrick Runs 6.728/183.02, Now #18; Best prior run: 13.731/61.57, Was #19
Gugliotta chattered the tires right off the starting line and he won't get in the show. Patrick spun the tires right at the hit and he won't make the show.
Left Lane: Bob Benza Runs 6.590/209.59, Now #15; Best prior run: 6.571/209.82, Was #15
Right Lane: Warren Johnson Runs 6.618/210.57, Now #17; Best prior run: 6.739/210.31, Was #19
Johnson with his quickest pass of the weekend, but he will not get in the show. Benza with another good pass, but will not improve and will start on Sunday. Bob Benza's incremental times: 60ft-0.976 sec., 330ft-2.756, 660ft-4.239/165.78 mph, 1,000ft-5.514.
Left Lane: Kurt Johnson Runs 6.537/210.93, Now #11; Best prior run: 6.548/211.06, Was #12
Right Lane: Steve Kent Runs 6.545/211.20, Now #13; Best prior run: 6.595/210.90, Was #16
Kent with his career quickest and fastest pass to move him up the ladder to the number 13 spot. Steve Kent's incremental times: 60ft-0.980 sec., 330ft-2.743, 660ft-4.211/167.53 mph, 1,000ft-5.477. Johnson with his quickest pass of the weekend to move up the ladder one spot. Kurt Johnson's incremental times: 60ft-0.972 sec., 330ft-2.730, 660ft-4.200/167.24 mph, 1,000ft-5.469.
Left Lane: Greg Stanfield Runs 6.557/210.41, Now #10; Best prior run: 6.532/210.93, Was #10
Right Lane: V. Gaines Runs 6.568/210.73, Now #14; Best prior run: 6.553/210.64, Was #14
A couple good pass, but neither driver improves...Greg Stanfield's incremental times: 60ft-0.979 sec., 330ft-2.741, 660ft-4.212/167.24 mph, 1,000ft-5.484.
V. Gaines' incremental times: 60ft-0.988 sec., 330ft-2.759, 660ft-4.230/167.26 mph, 1,000ft-5.499.
Left Lane: Ronnie Humphrey Runs 7.830/127.16, Now #9; Best prior run: 6.532/211.96, Was #9
Right Lane: Mike Edwards Runs 6.543/211.36, Now #12; Best prior run: 6.538/211.79, Was #12
Humphrey pushes in the clutch early. Edwards will not improve...Mike Edwards' incremental times: 60ft-0.979 sec., 330ft-2.740, 660ft-4.207/167.38 mph, 1,000ft-5.475.
Left Lane: Rodger Brogdon Runs 6.513/211.93, Now #4; Best prior run: 6.511/211.66, Was #4
Right Lane: Vincent Nobile Runs 12.380/70.00, Now #8; Best prior run: 6.527/211.89, Was #8
Brogdon with another good looking pass. Rodger Brogdon's incremental times: 60ft-0.973 sec., 330ft-2.726, 660ft-4.188/168.32 mph, 1,000ft-5.449. Nobile shakes and shuts off right off the starting line.
Left Lane: Erica Enders Runs 6.523/211.86, Now #3; Best prior run: 6.510/211.93, Was #3
Right Lane: Greg Anderson Runs 6.517/212.53, Now #7; Best prior run: 6.517/212.06, Was #7
Anderson with another good looking pass, second quick of the session. Erica Enders' incremental times: 60ft-0.973 sec., 330ft-2.730, 660ft-4.195/167.91 mph, 1,000ft-5.459. Enders is just a tick behind Anderson with the third quickest pass of the session. Erica Enders' incremental times: 60ft-0.973 sec., 330ft-2.730, 660ft-4.195/167.91 mph, 1,000ft-5.459.
Left Lane: Shane Gray Runs 6.511/211.66, Now #2; Best prior run: 6.510/212.46, Was #2
Right Lane: Allen Johnson Runs 6.523/212.39, Now #6; Best prior run: 6.514/212.53, Was #6
Gray with another great pass, just a tick off his qualifying time. Shane Gray's incremental times: 60ft-0.969 sec., 330ft-2.724, 660ft-4.185/168.18 mph, 1,000ft-5.446. Johnson with a good pass...Allen Johnson's incremental times: 60ft-0.974 sec., 330ft-2.732, 660ft-4.196/167.88 mph, 1,000ft-5.460.
Left Lane: Jason Line Runs 6.518/211.43, Now #1; Best prior run: 6.508/212.16, Was #1
Right Lane: Ron Krisher Runs 6.535/212.46, Now #5; Best prior run: 6.512/212.66, Was #5
Line with a real nice pass and will qualify No. 1 for the the 19th time. Jason Line's incremental times: 60ft-0.968 sec., 330ft-2.724, 660ft-4.188/167.76 mph, 1,000ft-5.452. Krisher was straight down the groove...Ron Krisher's incremental times: 60ft-0.974 sec., 330ft-2.741, 660ft-4.209/167.72 mph, 1,000ft-5.472.
Old Jun 5, 2011 | 09:28 AM
Round 1 Eliminations
Sunday
Results for Elimination Round 1
ENGLISHTOWN, N.J. - SUMMIT FastNews - Results of round 1 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals:
W/L Driver R-Time E-Time Speed
(W) Vincent Nobile (Mountainview Tire Avenger) 0.025 6.554 210.93
(L) Ronnie Humphrey (Genuine Hot Rod Hardware G 0.053 7.073 155.52
Weather conditions: air temperature 75 degrees, relative humidity 51 percent, barometer 29.99 inches, adjusted altitude 1,631 feet, track temperature 99 degrees. This is the first time Nobile and Humphrey have faced each other in eliminations. Nobile with the starting line advantage and never trailed as Humphrey pushed the clutch in early.
(W) Greg Stanfield (Nitrofish GXP) 0.019 6.570 210.05
(L) Greg Anderson (Summit Racing Equipment GXP) 0.037 6.568 210.97
Anderson is 20 - 14 against Stanfield in prior events. Stanfield with the starting line advantage and the power to hold on for the hole shot win. Greg Stanfield's MOV: 0.0163 seconds (approximately 5 feet). Anderson had a little wiggle right off the starting line.
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.038 6.536 211.86
(L) Kurt Johnson (Mark Christopher Auto Center 0.039 6.671 209.43
K. Johnson is 14 - 12 against A. Johnson in prior events. They both pre-stage and then they take their time staging, finally Kurt Johnson goes in first. They leave together and then Kurt Johnson's car makes a quick move toward the centerline, he reels it in. Allen Johnson was straight down the groove for the win.
(W) Rodger Brogdon (The Edge GXP) 0.084 6.531 211.26
(L) Steve Kent (Kent Trucking & Services GXP) 0.065 6.590 210.31
This is the first time Brogdon and Kent have faced each other in eliminations. Kent gets the starting line advantage, but Brogdon has the difference made up by the time they went by the Christmas tree. Rodger Brogdon's MOV: 0.0402 seconds (approximately 12 feet).
(W) Erica Enders (ZaZa Energy Cobalt) 0.029 6.539 211.13
(L) V. Gaines (Kendall Oil Avenger) 0.049 6.583 210.37
Enders is 1 - 0 against Gaines in prior events. Enders is out of the gate first and never trailed to take the win light. Enders will give up lane choice to Allen Johnson in the next round.
(W) Shane Gray (Service Central GXP) 0.113 6.562 210.80
(L) Larry Morgan (Lucas Oil/Summit Mustang) 0.077 9.664 92.87
Gray is 1 - 0 against Morgan in prior events. Morgan with the starting line advantage, but then has problems early and pushes in the clutch. Gray with a good looking pass for the win and will have lane choice over Stanfield in the next round.
(W) Jason Line (Summit Racing Equipment GXP) 0.054 6.526 211.16
(L) Bob Benza (BNB Racing GXP) 0.039 6.609 209.01
This is the first time Line and Benza have faced each other in eliminations. Benza with the starting line advantage, but Line has the difference made up by 60-feet and then runs low E.T. of the round for the win. Line will have lane choice over Nobile in the next round.
(W) Mike Edwards (Penhall/K&N/Interstae GXP) 0.040 6.538 211.76
(L) Ron Krisher (Valvoline GXP) 0.081 6.568 211.49
Edwards is 14 - 10 against Krisher in prior events. Edwards is out of the gate first and matches his qualifying time for the win. Edwards will give up lane choice to Brogdon in the next round.
From NHRA.com
Old Jun 5, 2011 | 11:03 AM
Round 2 Eliminations
Sunday
Results for Elimination Round 2
ENGLISHTOWN, N.J. - SUMMIT FastNews - Results of round 2 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals:
(W) Greg Stanfield (Nitrofish GXP) 0.016 6.566 210.70
(L) Shane Gray (Service Central GXP) 0.022 6.587 211.03
Weather conditions: air temperature 76 degrees, relative humidity 52 percent, barometer 29.96 inches, adjusted altitude 1,717 feet, track temperature 103 degrees. Stanfield is 3 - 1 against Gray in prior events. Stanfield is out of the gate first and never trailed as Gray had a little wiggle right off the starting line. Greg Stanfield's MOV: 0.0275 seconds (approximately 9 feet).
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.029 6.533 211.23
(L) Erica Enders (ZaZa Energy Cobalt) 0.031 6.547 211.36
Johnson is 2 - 1 against Enders in prior events. Johnson with a slight starting line advantage and never trailed for the win light. Allen Johnson's MOV: 0.0164 seconds (approximately 5 feet). Johnson will have lane choice over Stanfield in the semifinal.
(W) Mike Edwards (Penhall/K&N/Interstae GXP) 0.021 6.562 211.13
(L) Rodger Brogdon (The Edge GXP) 0.065 6.571 210.67
Edwards is 7 - 3 against Brogdon in prior events. Edwards with the starting line advantage and never trailed for the win by 0.0539 seconds (approximately 17 feet).
(W) Vincent Nobile (Mountainview Tire Avenger) 0.028 6.568 210.87
(L) Jason Line (Summit Racing Equipment GXP) 0.032 6.568 210.67
Line is 3 - 1 against Nobile in prior events. Nobile with a slight starting line advantage and the power to hold on for the hole shot win. They ran identical E.T.s...Vincent Nobile's MOV: 0.0041 seconds (approximately 15 inches). Nobile will give up lane choice to Edwards in the semifinal.
From NHRA.com
Old Jun 5, 2011 | 12:58 PM
Round 3 Eliminations
Sunday
Results for Elimination Round 3
ENGLISHTOWN, N.J. - SUMMIT FastNews - Results of round 3 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals:
(W) Vincent Nobile (Mountainview Tire Avenger) 0.030 6.629 210.83
(L) Mike Edwards (Penhall/K&N/Interstae GXP) 0.037 20.995 33.64
Weather conditions: air temperature 74 degrees, relative humidity 55 percent, barometer 29.94 inches, adjusted altitude 1,650 feet, track temperature 102 degrees. Edwards had problems with his first burnout, and went back to the water and got a good burnout the second time. Edwards is 1 - 0 against Nobile in prior events. Nobile is out of the gate first and never trailed as Edwards had problems as soon as he let the clutch out.
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.030 6.555 210.70
(L) Greg Stanfield (Nitrofish GXP) 0.040 6.559 210.87
Johnson is 12 - 6 against Stanfield in prior events. This is a great drag race as Johnson gets the starting line advantage and never trails. Allen Johnson's MOV: 0.0142 seconds (approximately 4 feet). Johnson will lane choice over Nobile in the final.
From NHRA.com
Old Jun 5, 2011 | 01:39 PM
Finals
Sunday
Results for Final Round
ENGLISHTOWN, N.J. - SUMMIT FastNews - Results of final, round 4 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 42nd annual NHRA SuperNationals:
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.013 6.689 210.64
(L) Vincent Nobile (Mountainview Tire Avenger) -0.006(R) 6.618 211.13
Weather conditions: air temperature 75 degrees, relative humidity 54 percent, barometer 29.92 inches, adjusted altitude 1,689 feet, track temperature 103 degrees. Nobile is 2 - 0 against Johnson in prior events and this is the first time they have faced each other in a final round. the last time there was an all Dodge final was Las vegas 2 in 2009. nobile is too quick on the tree and turns on the red light. Johnson collect his ninth Wally and his first since last year at Denver.
From NHRA.com
MReeves
Stock Eliminator
Jun 19, 2011 11:48 AM
MReeves
Funny Car
Jun 6, 2011 01:03 PM
MReeves
Super Stock
Jun 5, 2011 04:58 AM
MReeves
Super Gas
Jun 4, 2011 05:04 PM
MReeves
Stock Eliminator
Jun 14, 2010 09:49 AM
