O Reilly Super Start Fall Nationals Dallas
Old Sep 24, 2010 | 05:45 PM
Fri, 24 Sep 2010, 05:22 PM
Funny Car Qualifying Notes, Session #1
By Dave Rowe
ENNIS, Texas - Notes from round 1 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly Super Start Batteries NHRA Fall Nationals presented by Castrol Syntec listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Todd Simpson Runs 6.860/102.65, Now #1
Right Lane: Dale Creasy Jr. Runs 7.733/131.59, Now #2
3:17 p.m. Weather conditions: air temperature 95 degrees, relative humidity 44 percent, barometer 29.48 inches, adjusted altitude 3,801 feet, track temperature 141 degrees.
0-for-2 here, both go up in smoke quickly. Creasy hits the throttle as soon as he hits the throttle, Simpson gets a little further before he loses traction.
Left Lane: Jim Head Runs 6.006/110.69 begin_of_the_skype_highlighting 006/110.69 end_of_the_skype_highlighting, Now #1
Right Lane: Melanie Troxel Runs 7.116/85.36, Now #3
These two get a little further than the first pair but not by much. Head and Troxel have decent 60 foot times, .908 and .923, but then strike the tires about 300 feet out.
Left Lane: Jeff Arend Runs 4.348/239.65, Now #1
Right Lane: Cruz Pedregon Runs 5.121/146.42, Now #2
Arend gets down the track with no traction problems, the first car to do it so far, and he takes the early pole. Pedregon makes it to the 400 feet mark, goes up in smoke and backs off the throttle.
Left Lane: Del Worsham No Time, Now #8
Right Lane: Tim Wilkerson Runs 4.325/278.35, Now #1
Worsham gets about 100 feet out, strikes the tires and makes a violent move to the right before he backs off the throttle. Wilkerson makes an impressive run for the conditions and takes the pole for now.
Left Lane: Tony Pedregon Runs 4.744/192.66, Now #3
Right Lane: Ron Capps Runs 4.861/185.43, Now #4
4:09 p.m. We're back after a lengthy cleanup in the left lane. Worsham's car deposited some oil on the track staring around half-track.
Capps hits the throttle, gets about 300 feet out and strikes the tires. He pedals, gets to half-track, then makes a hard move to the right and has to give up on the run. Pedregon gets about 400 feet out, hazes the tires and pedals, then goes on through with a decent pass for the conditions.
Left Lane: Robert Hight Runs 5.370/142.36, Now #7
Right Lane: Bob Tasca III Runs 4.644/216.03, Now #3
Hight rattles the tires early, pedals, then loses traction about 400 feet out and gives up on the run. Tasca was on a decent pass but had problems late in the run.
Left Lane: Ashley Force Hood Runs 4.713/215.41, Now #4
Right Lane: Matt Hagan Runs 6.195/102.55, Now #10
Hagan makes it 400 feet and goes up in smoke. Hood was on a decent pass, then lost traction around half-track. She pedals a couple of times and runs quick enough to get in the fourth spot.
Left Lane: Jack Beckman Runs 4.441/251.34, Now #4
Right Lane: John Force Runs 4.407/254.90, Now #3
We finally get a side-by-side, the last pair of the round. Beckman was on a clean pass, then the rear of the car started moving around late in the run but he was able to hang on and stay on the throttle. Force went right down the groove and gets in the third spot.
Timing data courtesy of CompuLink
Old Sep 24, 2010 | 05:47 PM
Round 2 Qualifying
Fri, 24 Sep 2010, 08:36 PM
Funny Car Qualifying Notes, Session #2
By Dave Rowe
ENNIS, Texas - Notes from round 2 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly Super Start Batteries NHRA Fall Nationals presented by Castrol Syntec listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Paul Lee Runs 4.301/284.03, Now #1; No Prior Run
Right Lane: Jeff Diehl Runs 5.033/163.83, Now #10; No Prior Run
6:53 p.m. Weather conditions: air temperature 89 degrees, relative humidity 55 percent, barometer 29.45 inches, adjusted altitude 3,487 feet, track temperature 114 degrees.
Track conditions have improved greatly from the first round. Lee makes an impressive run here and moves all the way to the top spot. Diehl makes a nice pass and gets in the show in the tenth spot for now.
Left Lane: Dale Creasy Jr. Runs 5.191/247.88, Now #13; Best prior run: 7.733/131.59, Was #17
Right Lane: Del Worsham Runs 4.249/277.43, Now #1; No Prior Run
Creasy gets about 300 feet out, strikes the tires, pedals several times and gives up on the run. Worsham makes a good run and gets in the top spot for now.
Left Lane: Melanie Troxel Runs 5.347/135.40, Now #15; Best prior run: 7.116/85.36, Was #18
Right Lane: Todd Simpson Runs 4.362/271.84, Now #5; Best prior run: 6.860/102.65, Was #17
Troxel was on a good run but strikes the tires about 500 feet out. Simpson keeps the candles lit all the way through the run and gets in the show, bumping out Head and putting Hight on the bump.
Left Lane: Matt Hagan Runs 7.527/82.74, Now #18; Best prior run: 6.195/102.55, Was #18
Right Lane: Jim Head Runs 6.725/94.85, Now #17; Best prior run: 6.006/110.69 begin_of_the_skype_highlighting 006/110.69 end_of_the_skype_highlighting, Was #17
Hagan gets about 200 feet out, loses traction and backs off the throttle. Head rattled the tires off the line, started drifting to the left, then gave up on the run about 300 feet out.
Left Lane: Cruz Pedregon Runs 4.129/299.26, Now #1; Best prior run: 5.121/146.42, Was #13
Right Lane: Robert Hight Runs 4.183/287.66, Now #2; Best prior run: 5.370/142.36, Was #16
This was a great side-by-side, both cars right down the groove, header flames high and steady, with the quickest runs of the weekend so far.
Left Lane: Ron Capps Runs 5.135/141.80, Now #13; Best prior run: 4.861/185.43, Was #13
Right Lane: Tony Pedregon Runs 4.263/251.86, Now #4; Best prior run: 4.744/192.66, Was #12
Capps was on a decent pass but started losing traction about 400 feet out. Pedregon started mixing up cylinders late in the run but still made a good run to move up to the fourth spot.
Left Lane: Bob Tasca III Runs 4.200/289.45, Now #3; Best prior run: 4.644/216.03, Was #11
Right Lane: Ashley Force Hood Runs 5.133/147.97, Now #12; Best prior run: 4.713/215.41, Was #12
Hood gets to the 330 foot mark, loses traction and backs off the throttle. Tasca keeps the candles lit all the way through the run and moves all the way to the third spot.
Left Lane: John Force No Time, Now #11; Best prior run: 4.407/254.90, Was #10
Right Lane: Jack Beckman Runs 4.225/293.47, Now #4; Best prior run: 4.441/251.34, Was #11
Force gets out of the groove about 300 feet out. He starts moving to the right, the rear of the car starts moving around, then he makes a move toward the right and takes out the last timing block. Beckman was out in front and crossed the finish line before Force so he will get his time.
Left Lane: Tim Wilkerson Runs 4.181/282.90, Now #3; Best prior run: 4.325/278.35, Was #8
Right Lane: Jeff Arend Runs 4.163/290.76, Now #2; Best prior run: 4.348/239.65, Was #9
A good way to end this round, these two were glued together all the way through the run.
Old Sep 25, 2010 | 05:09 PM
Round 3 Qualifying
Sat, 25 Sep 2010, 07:02 PM
Funny Car Qualifying Notes, Final Session
By Dave Rowe
ENNIS, Texas - Notes from round 3 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly Super Start Batteries NHRA Fall Nationals presented by Castrol Syntec listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Jim Head Runs 4.194/299.33, Now #6; No Prior Run
Right Lane: John Force Runs 4.170/294.63, Now #3; Best prior run: 4.407/254.90, Was #11
12:12 p.m. Weather conditions: air temperature 78 degrees, relative humidity 73 percent, barometer 29.53 inches, adjusted altitude 2,670 feet, track temperature 94 degrees.
A good side-by-side, Head and Force right down the middle of the lanes. Head wasn't in the field but makes a clean pass to move all the way to the sixth spot. Force improves and moves into he third spot.
Left Lane: Ashley Force Hood Runs 4.100/307.72, Now #1; Best prior run: 4.713/215.41, Was #13
Right Lane: Matt Hagan Runs 4.291/295.72, Now #12; No Prior Run
Hagan had a good 60-foot time, then has to pedal to settle down the slicks. he keeps it in the groove and goes on through with a decent pass to get in the show in the twelfth spot for now. Hood makes her quickest pass of the weekend and takes the pole for now.
Left Lane: Jeff Diehl Runs 7.146/99.24, Now #15; No Prior Run
Right Lane: Melanie Troxel Runs 8.840/74.53, Now #16; No Prior Run
Troxel gets about 200 feet out, breaks the tires loose and backs off the throttle. Diehl gets a little further, pedals once, then gives up on the run.
Right Lane: Dale Creasy Jr. Runs 5.835/212.43, Now #15; No Prior Run
5:39 p.m. Weather conditions: air temperature 76 degrees, relative humidity 76 percent, barometer 29.41 inches, adjusted altitude 2,663 feet, track temperature 88 degrees.
We're back after a five hour rain delay. We will finish this round and go right into the last session of Pro Qualifying. This will be the only round of Funny Car qualifying.
Creasy gets about 200 feet out and strikes the tires. he pedals, makes a move toward the wall and backs off the throttle. He rolls about 100 feet, gets back on the throttle and the rear of the car starts moving around. He pedals again, gets close to the wall and backs off the throttle.
Left Lane: Tony Pedregon Runs 7.963/91.19, Now #12; Best prior run: 4.263/251.86, Was #11
Right Lane: Ron Capps Runs 4.129/300.40, Now #2; No Prior Run
Pedregon rattles the tires hard off the line and gives up on the run quickly. Capps makes this final attempt count, going right down the groove and going all the way to the second spot.
Left Lane: Del Worsham Runs 8.512/77.64, Now #12; Best prior run: 4.249/277.43, Was #11
Right Lane: Paul Lee Runs 4.205/292.71, Now #10; Best prior run: 4.301/284.03, Was #14
Worsham had a repeat of Pedregon's run, rattling the tires at the hit, then backing off the throttle quickly. Lee makes a clean pass and moves up to the tenth spot.
Left Lane: Jack Beckman Runs 4.132/305.01, Now #5; Best prior run: 4.225/293.47, Was #11
Right Lane: Bob Tasca III Runs 4.126/302.89, Now #2; Best prior run: 4.200/289.45, Was #9
Beckman is able to tame the left lane on this pass. He goes right down the groove and is able to move into the top half of the filed to the fifth spot. tasca makes his quickest pass of the weekend and moves into the second spot for now.
Left Lane: Robert Hight Runs 4.517/191.08, Now #9; Best prior run: 4.183/287.66, Was #9
Right Lane: Tim Wilkerson Runs 4.079/305.77, Now #1; Best prior run: 4.181/282.90, Was #8
Hight was on a great pass but started drifting to the right. He gets about 600 feet out, gets close to the centerline, then wisely backs off the throttle. Wilkerson makes an impressive run, going right down Broadway with the quickest pass of the weekend to take th top spot.
Left Lane: Jeff Arend Runs 4.121/305.56, Now #3; Best prior run: 4.163/290.76, Was #7
Right Lane: Cruz Pedregon Runs 12.411/41.55, Now #6; Best prior run: 4.129/299.26, Was #5
Pedregon strikes the tires at the hit and has to give up on the run. Arend makes an impressive run and moves into the third spot
That will end qualifying for the Funny Cars with Wilkerson on the pole and Creasy on the bump.
A notable first round match-up tomorrow will be Force vs. hight.
From DragRaceCentral.com
Old Sep 27, 2010 | 04:33 AM
Eliminations
Sun, 26 Sep 2010, 08:10 PM
Summary of Eliminations in Funny Car
ENNIS, Texas - Summary of eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly Super Start Batteries NHRA Fall Nationals presented by Castrol Syntec:
Round 1:
Jack Beckman, Norco CA, '10 Charger, Left lane, (0.111) 4.124 302.08 def. Jim Head, Columbus OH,'10 Solara, (0.081) 12.909 70.68
Ashley Force Hood, Yorba Linda CA, '10 Mustang, Left lane, (0.111) 4.089 308.57 def. Todd Simpson,Ponder TX, '00 Camaro, (0.119) 4.789 180.96
Matt Hagan, Christianburg VA, '10 Charger, Right lane, (0.076) 4.105 305.15 def. Jeff Arend, SanDimas CA, '08 Solara, (0.100) 4.117 308.07
Bob Tasca III, Cranston RI, '10 Mustang, Left lane, (0.110) 4.136 301.87 def. Tony Pedregon,Brownsburg IN, '09 Impala SS, (0.086) 4.234 286.6
2Del Worsham, Chino Hills CA, '10 Camry, Right lane, (0.082) 4.131 302.48 def. Ron Capps, CarlsbadCA, '10 Charger, (0.077) 4.145 301.07
Tim Wilkerson, Springfield IL, '10 Mustang, Left lane, (0.135) 5.027 188.62 def. Dale Creasy Jr.,Beecher IL, '09 Impala SS, (0.099) 7.447 108.08
Cruz Pedregon, Brownsburg IN, '10 Solara, Left lane, (0.236) 4.101 296.11 def. Paul Lee, AnaheimCA, '10 Impala SS, (-0.187 foul) 9.559 75.59
John Force, Yorba Linda CA, '10 Mustang, Left lane, (0.110) 4.144 309.34 def. Robert Hight, YorbaLinda CA, '10 Mustang, (0.093) 6.170 110.42
Round 2
Worsham, Left lane, (0.098) 4.085 309.49 def. B Tasca III, (0.082) 4.179 301.40
J Force, Left lane, (0.085) 4.083 308.21 def. T Wilkerson, (0.052) 4.168 293.73
M Hagan, Right lane, (0.087) 4.062 306.74 def. C Pedregon, (0.106) 4.384 221.60
A Force Hood, Left lane, (0.135) 4.085 308.92 def. J Beckman, (0.079) 4.431 237.46
Round 3:
J Force, Left lane, (0.087) 4.107 301.47 def. D Worsham, (0.106) 5.738 223.54
M Hagan, Left lane, (0.089) 4.111 300.26 def. A Force Hood, (0.093) 4.178 300.26
Round 4:
M Hagan, Right lane, (0.060) 4.155 294.63 def. J Force, (0.075) 4.491 203.74
Low ET: Matt Hagan 4.062 seconds
Top Speed: Del Worsham 309.49 MPH
MReeves
Super Gas
Sep 27, 2010 01:21 PM
MReeves
Stock Eliminator
Sep 27, 2010 01:19 PM
MReeves
Pro-Stock
Sep 27, 2010 04:26 AM
MReeves
Super Stock
Sep 23, 2010 01:20 PM
MReeves
Sep 25, 2009 04:00 AM
