318 Compression question
Old Oct 6, 2011 | 07:43 PM
Altosax's Avatar
Today I put a re-built head on my van. I did a quick compression test without intake, spark plugs, push rods, rockers, etc. Compression is consistent but only showed like 62 psi in ea hole, second test showed 30-ish. Is this because nothing is really oiled up - rings whatever? Maybe some other reason? I had good compression before head removal (had damage from junk in cyl).
Please advise this oldie newb. Thanks.
Old Oct 6, 2011 | 08:12 PM
Without the rockers and push rods the valves do not open= no compression
Old Oct 6, 2011 | 08:53 PM
Altosax's Avatar
Huh? I thought the push rods umm pushed the valves open, against spring pressure, which tries to hold the valves closed. Am I wrong here?
Old Oct 6, 2011 | 10:15 PM
Altosax's Avatar
Thank you TVLynn. It took me a few to get it. Thanks for the lesson. Much appreciated. No air intake. I get it now.
Old Oct 7, 2011 | 04:59 PM
scotts74birds's Avatar
It sounds like a perfect set-up for compression-leakdown test!
65civilcuda
Jan 20, 2015 06:55 AM
440 aspen
Apr 6, 2014 09:49 PM
69POLARA383
Jul 16, 2011 07:36 PM
Slice
May 21, 2011 08:10 PM
raycer5
Feb 4, 2009 05:09 PM
