340 or not to be....
Old Jun 11, 2009 | 09:40 AM
Crazy4Carz.Com's Avatar
Crank bearing size I believe is different.
Old Jun 11, 2009 | 04:26 PM
i think there is an old thread called 318 vs. 340 vs. 360
that might help you out
Old Jun 11, 2009 | 04:34 PM
Isn't the cam a little different too? I see what you are saying though. I know that there are race versions on the 340 out there. Not sure what makes them so special either.
Old Jun 11, 2009 | 04:42 PM
Polaradude's Avatar
I think there are actually a bunch of dimensional differences.
they probably have wider oil and water passages
Old Jun 11, 2009 | 05:06 PM
theomahamoparguy's Avatar
A 318 bore size is 3.91. A 340 bore size is 4.04.
I doubt you could bore ANY 318 (LA) to the size of a 340. That's .130 [thats more than an 1/8 inch!] Maybe an old polysphere could be bored that far, but I wouldn't try it. Yes the crank has the same stroke (3.31) and the main bearing diameters are the same but most 340's had a quality forged steel crank (except the 73's). Hard to find. The 360 had the larger main bearings and a 4.00 bore. Not sure if the block was any tougher. The 340 had the better flowing heads with the 2.02 intake valve. The 360 had a similar head but the intake valve size was 1.88. (mostly). The one that is really rare is the 340 T/A block. It was stronger than the standard 340 block.
Old Jun 12, 2009 | 12:50 PM
chlngr1970's Avatar
The 360 had a smaller bore but a longer stroke. Like the 400 vs 440. 400 has a larger bore and the 440 has a longer stroke. That is why you get more CID with a 400 block and a 440 crank. The earlier 340s had better heads than the late ( 73 ) 340s and 360s. Heads have nothing to do with CID, just bore and stroke. IIRC, the formula is .7854XBoreXBoreXStrokeX# of Cylenders. If I were you, I would find a good starter 360 and run with it!
Even better, drop a big block in that A-Body!
j
