360 performance
i have a 360 bored .30 over with a mild cam i was wondering what would be a good set of heads and an intake i have the stock intake and i have 2.02 heads now should i stick with those heads or is there something better out there im also running a elderbrock 650 also have 4.10 gears im building the truck for tug a truck or truck pulling
More info? Where are the pistons in the hole? Dished? Flat tops? Cam specs? Do you have a goal in mind for torque needed? Budget?
Just for reference I gained 41 RWHP by removing ported 340 X heads & installing ported 308s with stock valve sizes . So they are better heads for a production head , The RHS heads are a good choice aftermarket , but most 360s had very low compression so that should be addressed as well if it is stock , an RV cam will help build cylinder pressure .
