360 performance
Old Dec 4, 2012 | 03:01 PM
ClemM882's Avatar
360 performance
i have a 360 bored .30 over with a mild cam i was wondering what would be a good set of heads and an intake i have the stock intake and i have 2.02 heads now should i stick with those heads or is there something better out there im also running a elderbrock 650 also have 4.10 gears im building the truck for tug a truck or truck pulling
Old Dec 4, 2012 | 03:37 PM
PK1's Avatar
PK1
More info? Where are the pistons in the hole? Dished? Flat tops? Cam specs? Do you have a goal in mind for torque needed? Budget?
Old Dec 4, 2012 | 05:10 PM
Chryco Psycho's Avatar
Just for reference I gained 41 RWHP by removing ported 340 X heads & installing ported 308s with stock valve sizes . So they are better heads for a production head , The RHS heads are a good choice aftermarket , but most 360s had very low compression so that should be addressed as well if it is stock , an RV cam will help build cylinder pressure .
68Dart
Mar 17, 2019 05:43 PM
dpmalibu
Aug 3, 2013 06:05 PM
NYH1
Jul 2, 2009 11:03 AM
TwistedWrenches
Mar 12, 2009 07:28 PM
choelzer
Feb 29, 2008 03:00 AM
