Mopar Forums (/forums/)
-   Do-It-yourself Section (https://moparforums.com/forums/f6/)
-   -   58 plymouth 318 poly distributor firing order (https://moparforums.com/forums/f6/58-plymouth-318-poly-distributor-firing-order-7121/)
vintagenc2 Aug 5, 2010 10:14 PM
NEWBIE be nice:)
im just purchased a 58 plymouth custom surburban that has been sitting in a garage since 1965.
Im trying to get this running.
I imaging the black dot refering to the distributor in the diagram below is to the right of the clip?
thats 1 and the distibutor should be pointing there at TDC.
ok now going clockwise on the distiributor cap what comes after 1 does it go 18436572? run me around in the circle.
ok now, when do you set the gap in the points.and whats the points gap setting? .014?
I can time motorcycles with points but new to cars, im a quick learner though.
http://i112.photobucket.com/albums/n...IRINGORDER.jpg
1966sportfury Aug 5, 2010 11:28 PM
firing order 1-8-4-3-6-5-7-2 point gap is .015~.018
to set the point pop the cap, theres a small tab on the points that runs on the cam of the dist' there are 8 high points thats where you want that tab to be, (any one) the points should be open, then stick your fealer gauge in and set the points, with a screw driver,
vintagenc2 Aug 6, 2010 02:13 PM
got it. if all is in order it should fire, ill let you know what happends
