A-727 Front Seal
Old Apr 5, 2011 | 04:46 PM
DodgeRamFan23's Avatar
Question A-727 Front Seal
How do you install the front seal on an A-727 without the proper tools?
Old Apr 5, 2011 | 07:01 PM
moparman63's Avatar
Which seal are you talkin about? There are two up front. The large seal that goes around the front pump and the smaller seal that installs where the torque converter slips in. Assuming you're referring to the smaller one, just get a fairly large flat blade screwdriver and pry it out. Spray it clean with some brake cleaner. It won't hurt a thing as it evaporates completely. Then coat the new seal's outer housing with a thin coat of silicone and tap it in with a small ball peen.
Old Apr 5, 2011 | 08:24 PM
I am talking about the smaller seal. Dont you have to use a punch or something to make it go in evenly? Or does it need to go in evenly?
Old Apr 6, 2011 | 04:45 AM
moparman63's Avatar
No. If the seal housing has no flange, simply tap it in until the outside of the housing is flush with the front pump. If it has a flange, just tap it in until the flange bottoms against the front pump. You may run into either design of seal. Be careful removing the old seal. I have seen people drive a screwdriver straight into the outer seal housing and right into the front pump where the seal bottoms and gouge a hole into the front pump and ruin it. This is why you pry the seal out by sticking the screwdriver inside the seal and prying it right out. It will come right out.
Old Apr 6, 2011 | 05:46 PM
John Van's Avatar
Once that new seal is in,lubricate it with a little tranny fluid
Old Apr 7, 2011 | 10:58 PM
Thanks for the advice. Im not going to be able to work on my truck until this weekend.
Old Apr 9, 2011 | 07:33 PM
Ok, I got it in. Thanks for the help.
mopar383
Dec 17, 2014 12:55 AM
demetri
Feb 26, 2014 07:32 PM
Shrug
Mar 26, 2013 04:41 PM
72D100dodge
Apr 15, 2012 07:15 PM
furyaboveall
Oct 2, 2010 08:04 AM
