Can't crank/turnover engine
Old Aug 10, 2009 | 08:46 PM
68 Sat's Avatar
Trying to crank the engine at the 1 1/4 bolt at the harmonic balancer. I have WD 40 all the cylinders and can't get the thing to budge. What can I do to free it up.
Attached Thumbnails Can't crank/turnover engine-dsc06310.jpg   Can't crank/turnover engine-dsc06311.jpg   Can't crank/turnover engine-dsc06312.jpg
Old Aug 10, 2009 | 08:51 PM
pour some oil onto the valves
then add some more into the cylinders
Old Aug 11, 2009 | 06:22 PM
mr340's Avatar
Soak the cylinders with brake fluid for a few days, and try again.
Old Aug 11, 2009 | 07:33 PM
Polara_68's Avatar
MoparMania-no cure for it
I've used a 50/50 mix of diesel fuel & automatic transmission fluid -
fill the cylinders, let it soak at least 24 hours..
I've also used PB Blaster, too..
Old Aug 11, 2009 | 10:38 PM
theomahamoparguy's Avatar
fill the cylinders up with diesel/trans fluid mix. through the plug holes and down the intake ports. Let it sit for 3 days, keep pourin' in the mix to keep it topped up.
Next option; hand grenade or dynamite....just kiddin'..........
Old Aug 12, 2009 | 09:15 AM
68 Sat's Avatar
Can I use unleaded gasoline instead of diesel ?
Old Aug 12, 2009 | 12:12 PM
Have you taken the oil pan off to see what the bottom end looks like? Do you know how long the motor has been sitting?
Old Aug 12, 2009 | 12:14 PM
68 Sat's Avatar
taking the oil pan and heads off tonight to get a better look at whats going on. Been sitting for 10 + years..
Old Aug 13, 2009 | 09:30 PM
68 Sat's Avatar
I think I am F..ked I pulled the heads
Let me know my options. I guess this just turned into a long term project.I don't mind but I want to do it right once..
Attached Thumbnails Can't crank/turnover engine-image001.jpg   Can't crank/turnover engine-image002.jpg   Can't crank/turnover engine-image003.jpg   Can't crank/turnover engine-image004.jpg   Can't crank/turnover engine-image005.jpg
Old Aug 13, 2009 | 09:32 PM
68 Sat's Avatar
more pics
a few more
Attached Thumbnails Can't crank/turnover engine-image006.jpg   Can't crank/turnover engine-image007.jpg   Can't crank/turnover engine-image008.jpg   Can't crank/turnover engine-image009.jpg   Can't crank/turnover engine-image010.jpg
Old Aug 13, 2009 | 09:35 PM
68 Sat's Avatar
Unhappy and the last 5
help me out
Attached Thumbnails Can't crank/turnover engine-image011.jpg   Can't crank/turnover engine-image012.jpg   Can't crank/turnover engine-image013.jpg   Can't crank/turnover engine-image014.jpg   Can't crank/turnover engine-image015.jpg
Old Aug 13, 2009 | 09:46 PM
scotts74birds's Avatar
I'm not a psycic, but I see a trip to the machine shop in your future.
Old Aug 13, 2009 | 09:50 PM
68 Sat's Avatar
Scotts,
Where would you start? Heads or a tear down of the block to re-hone the cylinder walls.
Old Aug 13, 2009 | 09:59 PM
I've never opened an engine that had looked like that, so I cant offer you any reliable advice. But I'm sure other members will have a better idea as to what direction would be best. I'd like to hear what they say.
Old Aug 14, 2009 | 03:53 AM
mr340's Avatar
That's not pretty. I'm gonna assume replacing it is not what you want to hear so, start here: Drop the crank, remove any piston that will come out easily ( mark them for location). next start with one bank and soak then from the top with the fluid of choice (brake fluid or 50/50 diesel-trans fluid). let it sit for a week or two, keep it wet. Then use a hammer and a piece of wood and try to pop them loose starting from the rod end. Don't hit too hard, we don't want to break anything. Keep working it like this till they are all out. It could take some time. Once they are all out have a machine shop crack check the block before going any further.
Old Aug 14, 2009 | 08:17 PM
the block has to be brought to a machine shop
besides the rust, the block has to be checked
the deck may have to be evened out
back to the rust- you never wanna see rust in the combustion chamber
Old Aug 18, 2009 | 05:33 AM
MyDodgeDip's Avatar
Junior Member
That 440 68 new yorker in your other thread is still available, it's my father's car. You can hear it run and drive it up onto your trailer. (It stops too )
Unless that motor you got was super cheap I think you should re-consider that friendship.
Old Aug 18, 2009 | 06:35 AM
68 Sat's Avatar
I pulled the oil pan last night and all looks good. The pistons and crank actually look as described. I'm going to pull the crank and pistons and evaluate the situation thoroughly.
Your dad seemed like a good guy and his 68 New Yorker has potential for me. I am still going to need a tranny at the very least. Thanks for the heads up. do you have your dads #?
btw,
My buddy said he would give me the back...either way I'm ok...
Old Aug 18, 2009 | 08:26 AM
MyDodgeDip's Avatar
Junior Member
sounds like a good deal then. It's never bad to have a spare engine! (Then again, you're talking to the king of all hoarders..)
Old Aug 18, 2009 | 02:43 PM
68 Sat's Avatar
440 re-build detour
Thanks for all the feedback....
Any idea as to what I should expect to pay to re-bore these cylinder walls?
I guess I'll need new piston rings as well. I'm ok with this and actually having fun breaking it all down even though I wish it wasn't so bad.
With that said what would you guys do now that the engine is dismantled. I'm looking ideally for 300-400HP with street manners. I was thinking:
  • 4 barrel
  • dual plane intake
  • 440 source heads/ or ??? suggestions
  • not sure if I should keep pistons and cast crank
  • HP exhaust manifolds
Kind of like a sleeper look under the hood with some Big *****!!!
Old Aug 18, 2009 | 03:02 PM
  • 4 barrel
  • dual plane intake
check the other thread
Boat Guy
May 24, 2014 03:06 PM
Phils66dodgecoronet
Aug 2, 2012 04:28 PM
67 Fury
Jan 7, 2010 10:29 PM
atowncris
Nov 19, 2009 12:48 PM
Pito's 74
Oct 5, 2008 11:29 PM
