chop top
Guest
Posts: n/a
Hey, Ryan
It's a pretty ambitious project, even for somebody that's done it before. I havent done it either, but what I do know is that the roof shell has to be cut into quarters (1/4ths) and then 'stretched out' by adding material in order for the pillars to line up. (As a visual, imagine taking a pyramid shaped object and removing a section (chop). Now try attatching the two halves together - don't fit!
The glass will have to be "tempered safety glass" in order to meet federal regs. Can be custom made, but costly. If your project is for the strip, the requirements will likely be different. Good luck!
Mark
Mark
Guest
Posts: n/a
alright thanks for the advice and it was lexan that i was thinking about and i didn't know it was illegal, and from what i can gather it would be a big project just like bighammer said, so if i do do it i will probably take it some where to be done,
