Dizzy orientation, 383
Old 09-04-2009 | 06:24 PM
scotts74birds's Avatar
I'm ready to stab the dizzy but am confused about the orientation because I've seen it differently done in two places. First, where should the vacuum can point? And what is the common location of the #1 terminal? A picture of someones big block set-up, with #1 identified, would be perfect. Thanks
Old 09-04-2009 | 07:40 PM
Crazy4Carz.Com's Avatar
It really doesn't matter as long as you have enough swing to adjust the timing. You can point the rotor anywhere and make that #1, just be sure you are on TDC on the compression stroke not the exhaust. It is an easy mistake to make, I have done it myself.
Old 09-04-2009 | 08:08 PM
crmzendrgone's Avatar
Not sure but the other day i lifted the hood on my doba and found it still has the manufacturer's lable for information. One was of the vacuum routing would that help? If so i will post a picture.
Old 09-04-2009 | 08:16 PM
Just thinking I took some photos of my engine before I pulled it. I'll see if i can find them.
Old 09-04-2009 | 08:18 PM
Thanks, but all set now. I was just confused by conflicting info in two books. Dizzy is now stabbed. Tomorrow looks like a good day for putting the match to it. Thank you guys.
Old 09-04-2009 | 08:21 PM
Sweet!!!
Old 09-04-2009 | 08:27 PM
I feel like I have missed some while i was offline for that while. Are you working on your roadrunner?
Old 09-04-2009 | 08:57 PM
Yes, starting to get a few $ coming in now and can finally get some things rolling. Scored a pair of perfect fenders last weekend.
Old 09-05-2009 | 04:25 PM
Ok, #1 terminal has been decided. Not by me, but cause the previous owner cut the plug wire to length and it will only reach 1 terminal! HaHa.
Old 09-05-2009 | 06:43 PM
t LIFE, LIFE! I've done it.....LIFE! .......IT LIVES!!
Old 09-06-2009 | 06:56 PM
HAHA
great
Old 09-08-2009 | 08:45 AM
That is awesome. I think your a wizard with misc. photos.
Old 10-04-2009 | 07:06 PM
MrOldart2U's Avatar
Where does he find that stuff??lol
Old 10-04-2009 | 11:18 PM
theomahamoparguy's Avatar
one of my favorite movies!
Old 10-05-2009 | 09:00 PM
rr69half6bbl's Avatar
scotty, # 1 wire is the firts plug in on the cap passed the locking clip on the pass. side of the dist, opposite side of the vac. pot., dont forget counter clock rotation. then the point on the vac. pot should point straight up to the end of the front bowl, then turn it towards rad hose. while cranking till it hits.
labradorian70
09-24-2014 10:44 AM
maca
07-12-2014 09:48 PM
jordanz
27
10-16-2012 07:30 AM
64fury
09-02-2010 04:58 PM
scotts74birds
06-16-2009 08:39 PM
