Engine movement limiters AGAIN
Old 04-07-2010 | 10:14 AM
Archer's Avatar
OHD -
I went to neoprene motor / trany mounts and the engine does not move. The downside is that more vibration is transferred to the cabin. Guessing the engine is putting out about 525 HP (based on previous ETs), and since she's a cruiser these days, no need to lock it down any tighter.
Maybe I'm missing something (not the first time). but anything with zero flex usually translates in to a broken part ...
Old 04-07-2010 | 10:22 AM
Why not install some gussets?
Old 04-07-2010 | 01:21 PM
MrOldart2U's Avatar
Originally Posted by OHD
What do you guys use to limit the front to rear movement, when taking off and stopping, on your high performance cars.
The car I am putting together needs them to keep the engine in the exact same place ALL THE TIME. We are using front and rear plates that it flexes when taking off/stopping.
Pics would help, and also how can you tell its moving fore and aft? Seems a motor plated motor wouldn't have fore/aft movement enough to matter.... what type of vehicle is this in? Just needing more facts before trying to guide.....IF these are factory pieces (engine plates) they shouldn't have any movement and I would doubt that the vehicle in question can generate the G-Forces necessary to allow movement. ( NO BS intended)
Old 04-07-2010 | 03:04 PM
My friend runs a dragster with 1200 hp and runs over 188 miles per hour in a quarter mile and he has never heard of front to rear limiters.. He has a front plate and a mid plate between the engine and tranny. If your plate is flexing your plate is too thin... JMO....
Old 04-07-2010 | 06:04 PM
MrOldart2U's Avatar
the "attaching points" are not flexing, the mid part of the plates between the attachment points are.....
I have been bringing this topic up for 3-4 years now and some have realized and come up with very creative "limiters" that work great for their applications. Seems nobody has the same piece of crap I do, so I can copy theirs, though.
There are several kits commercialy available but all made for Chev and Fords
Ran across this by doing a Google search , although it looks as though this one bolts to the bolt hole of one of the motor mount bosses.....http://www.cheperformance.com/CartGenie/prod-208.htm
Although these are listed as a piece for the s-197 chassis mustang you may be able to 'adapt' it for your car....
Old 04-08-2010 | 03:45 AM
Do you have any pics of where they broke and where they are flexing? I'm sure that would help us to assist you.
Old 04-09-2010 | 01:45 PM
https://www.appliedracing.net/index....cfe48859f1437d
here are few examples of the available kits,,,,
for those not aware of the movement...IN EVERY CAR......
After seeing these, I now know what you are talking about. Only thing is, I don't see how you would be abel to tie them into the motor minus at the motor mount bracket and then run the shaft down the frame rail and then weld it in at a crossmember or along the frame rail. Where ever you weld it though, you would need to box in the mounting area and throw in a few gussets (3/8" or thicker) for added stength. You would also have to hard mount the motor and tranny to the frame, which would help in keeping the motor movement to very little if not eliminate it completely.
Old 04-09-2010 | 10:27 PM
Ah the heck with it. Just weld in some DOM tubing and call it good.
Old 04-09-2010 | 11:56 PM
toad490's Avatar
I have about 1050HP+ in a 3000lb
The motor flexes a .375 aluminum front plate (cracked last one).
If you're getting that much flex with a midplate and front plate and you're only making 1050hp you have some very serious design problems, you need to take it to a good chassis shop and get it sorted out. Properly designed cars making serious hp have no problems using just a front plate.
PS. next time you get a plate made have it made with aircraft grade aluminum. It will go thru thousands of flex cycles (launches) and not crack, just watch the flex of the wings of a plane next time your on one.
Old 04-10-2010 | 04:29 AM
PS. next time you get a plate made have it made with aircraft grade aluminum. It will go thru thousands of flex cycles (launches) and not crack, just watch the flex of the wings of a plane next time your on one.[/quote]
Hey Toad, you are right... I see that every week and at first it scared me to death.... They move A LOT!!!!!!!!!!!
Old 04-10-2010 | 12:08 PM
i know and have seen two ways
most mopars came with a hook (after 66 i believe) that connected from the k-frame to the motor
this was put there in response to chevy's rat motor mounts constantly breaking
if you car did not come with this, just line up where the motor's mounts would be, and where that would line up to on the k-frame
drill the k-frame
and attach the bolt through it
Old 04-13-2010 | 05:45 PM
toad490's Avatar
The sheer length makes them flex.
Well the ones you show in your pic are very short, what's up with that OHD????? And if your plates are cracking they are NOT 6062, get a honest supplier.
Old 04-14-2010 | 08:48 AM
Polaradude's Avatar
[QUOTE=OHD;41677]I have about 1050HP+ in a 3000lb doorslammer leaving HARD on 32X14.5X15 slicks.
Love to see a picture of this car.
Old 04-14-2010 | 09:04 AM
  #24
toad490's Avatar
17 and 20 inches short? Waterpump to side of engine compartment is large span......
Exactly and the ones in the pic of the engine you posted in the other thread (& avatar) are not even close to that long???????
Old 04-14-2010 | 09:28 AM
  #25
johnthegoalie's Avatar
thinkin with me dipstick
ok, i've sat back and watched - seen the "questions" and responses - now can someone please fill me in, and with no dickery intended, is there a point to this thread?
Old 04-14-2010 | 05:52 PM
  #26
toad490's Avatar
About as much as there is to this one.
http://www.forbbodiesonly.com/moparf...ead.php?t=1441
or this one
http://www.moparchat.com/forums/showthread.php?t=108978
Old 04-14-2010 | 06:02 PM
  #27
mr340's Avatar
I've asked nicely once already for everyone to stop the bickering, if I have to ask again, I won't be so polite. That's all I have to say right now.
Old 04-14-2010 | 08:21 PM
  #28
toad490's Avatar
Well if OHD is the type you want on your site when every other decent Mopar site has banned him, please feel free to ban me. And that's all I have to say right now.
Old 04-14-2010 | 09:15 PM
  #29
mr340's Avatar
Don't recall anyone saying anything about banning.
Old 04-15-2010 | 04:18 AM
  #30
This thread is dead.
Quick Reply: Engine movement limiters AGAIN
