The Evil That is Carburtors
Old Aug 19, 2009 | 07:44 AM
Morrigan_Aria's Avatar
Hell kitten
We've had this discussion. I hate them too.
Old Aug 19, 2009 | 08:21 AM
Hell kitten
Hey, how come you can't type my name right?? What are you doing over there? You best be looking at Summit Racing online...LOL
Fuelie? No, I'm thinking we just need to pay someone to fix the carbs. Like I'd really suggest you go fuelie on the RR...jeesh. LOL
Old Aug 19, 2009 | 01:25 PM
sgp7679's Avatar
Yea im there with you about not liking carbs. I think we just need to learn how to adjust the correctly. I would never ruin my classic with injection tho ha. Its a love hate thing.
Old Aug 19, 2009 | 02:40 PM
scotts74birds's Avatar
I threw this out a few months ago, but im too poor now to follow up. Mega-squirt efi is a system that allows you to build your own efi system from off the shelf components.MegaSquirt® FAQ Main Page www.MSefi.com • Index page
Old Aug 19, 2009 | 02:43 PM
BTw are you using the right vacuum port? You want the timed vacuum port, not manifold.
Old Aug 19, 2009 | 04:59 PM
Havent priced it,but some of the feedback put it in the 1000-1500 range. Really not a kit, seems to be a programmable processor that you can use junkyard parts for, O2 sensor, build you own intake or install bungs on yours for injectors. I read that with the efi you dont need a dual plane intake. I'll troll the sites this weekend for more info.
Old Oct 4, 2009 | 06:13 PM
MrOldart2U's Avatar
And ported is ABOVE the base plate of the carb...
Old Oct 5, 2009 | 12:17 AM
theomahamoparguy's Avatar
Yes, must use "ported" manifold vacuum sorce for the dizzy. This will be a port on the carb that has low to no vacuum while the engine is idling. Should have this indicated with the install instructions. (for locating it).
BTW, the engine must idle with the throttle plates not opening too far, otherwise it will defeat the idea of the "ported" vacuum. If the throttle blades, while idling, go past a certain point, they will uncover the port, thus adding vacuum at all times. This is one of the reasons that holley throttle plates are drilled with holes on the primary side by racers. Drilling small holes in the throttle plates lets added air enter the engine while keeping the throttle plates at a more optimum opening angle. This smaller angle keeps the idle transfer and ported vacuum operating as designed.
Old Oct 5, 2009 | 12:31 AM
mega squirt could conceivably be very inexpensive if you know how to solder and like to scrounge parts a the junk yard. It was designed to be a learning tool to people wanting to learn about FI. Much reading is also required. If you wanted, you could even use an old carb as your throttle plate. just gut it and add a TPS sensor.
GEORGE68HEMIRR
Jan 31, 2010 03:49 AM
