HELP :) 70 Duster brakes
Old 02-21-2011 | 10:14 AM
The Dustman's Avatar
I have drum brakes in front and back ... i know they have a kit available but its a little expensive. does anyone know what car i can get front disks from that would work?
Old 02-21-2011 | 05:25 PM
blue 68 gts's Avatar
Any 67+ A-body disks will bolt up.
Most popular conversion is the 73-76 A-body big bolt pattern swap because more parts are readily available.
Old 02-21-2011 | 05:31 PM
chlngr1970's Avatar
To build on what blue 68 GTS posted, find an A-Body ( Dart, Duster, Dart Sport, Valiant, Scamp ) that has Disc brakes and take the whole setup. Upper and lower control arms, spindles, brake lines, proportioning valve, brake Master Cylinder, and if you so desire, Power Brake booster. Replace ware items like bearing, bushings, pads and maybe even new soft lines, and you will be set.
j
Old 02-25-2011 | 05:55 PM
scotts74birds's Avatar
This is mostly tailored to B-bodies, but this is the last word in factory Mopar brake swaps. It does include A-bodies too. good luck! http://www.moparaction.com/tech/archive/disc-main.html
pro-tech
08-14-2013 10:52 PM
The Dustman
04-08-2011 04:48 AM
samuelcosmo76
08-02-2010 05:57 PM
71RR08
09-22-2008 09:45 PM
mopardusterjeff
05-22-2008 04:18 PM
Quick Reply: HELP :) 70 Duster brakes
