HELP :) 70 Duster brakes
I have drum brakes in front and back ... i know they have a kit available but its a little expensive. does anyone know what car i can get front disks from that would work?
To build on what blue 68 GTS posted, find an A-Body ( Dart, Duster, Dart Sport, Valiant, Scamp ) that has Disc brakes and take the whole setup. Upper and lower control arms, spindles, brake lines, proportioning valve, brake Master Cylinder, and if you so desire, Power Brake booster. Replace ware items like bearing, bushings, pads and maybe even new soft lines, and you will be set.
j
j
This is mostly tailored to B-bodies, but this is the last word in factory Mopar brake swaps. It does include A-bodies too. good luck! http://www.moparaction.com/tech/archive/disc-main.html
