HELP Unexplained Stall D150
Old Jan 3, 2009 | 04:01 AM
Crazy4Carz.Com's Avatar
Check your electrical connections. Like at the coil for a loose wire that may be making a poor contact and breaking loose under load.
Old Jan 3, 2009 | 12:44 PM
challenger's Avatar
cant remember but do you have a silinoid ( cant spell today ) on the carb if so check to make sure its working fine and make sure your carb is clean and tight to the manifold ..... any vacuum leaks that you can hear or find ?
Old Jan 5, 2009 | 06:39 PM
smackhonda's Avatar
Make sure the float level is set correctly on the carb, if its set low that would explain why it is stalling because the fuel will slosh to one side and not be picked up. Also check and see if when your trucks at that angle of when its stalls if any wire looms are being pinched or pulled on that would make a bad connection
Potterymaker1
Feb 10, 2012 07:02 PM
sgp7679
Aug 21, 2009 07:19 PM
cfryerson
Aug 21, 2009 07:56 AM
Budsjlm
Aug 20, 2009 12:41 PM
thedusterridesagain
Jun 4, 2009 04:26 PM
