need help with 69 dart
Old Dec 4, 2008 | 04:55 AM
Commando's Avatar
What kind of oil are you running in it? If it does not have zinc you could be destroying the cam and in turn causing these problems.
Does the knock go away at high speeds, or can you not hear it anymore?
Old Dec 4, 2008 | 11:59 AM
BuckNeccid's Avatar
If that engine is actually a 25 to 1 compression, you've probably blown head gaskets, unless it's been O-ringed. 25 to 1 is an EXTREME compression, more than even diesel, and if you haven't blown the gaskets, then you're most likely getting pre-ignition WAY before TDC, just from the compression of the fuel in the cylinder, before the spark plug fires. A moderate compression ratio is about 9 or 10 to 1, racers will use 12 to MAYBE as high as 15 to 1, so you can see how high that ratio is?
Old Dec 5, 2008 | 10:32 AM
BuckNeccid's Avatar
Just to give you a rough idea of what the compression actually is, get a compression guage, take a reading of any cylinder compression, then divide it by 15 (Mean atmospheric pressure) if it's 10-1, it'll be about 150 (assuming 100% efficiency). More realistic, figure 125-130 to be a 10-1 compression. If you turn the engine over and your compression guage blows up.... you probably DO have a 25-1 compression. I think most guages only go to about 300 lbs.
Just a chance, but take the cap off your distributor, and look at the mechanical advance system. Check for missing or broken springs, sticking weights, Sticking plates, anything that might cause it to advance timing and stick. If you don't want to go to all the trouble of taking the distributor down, just spray some WD-40 down inside it, generously, and see if that might help by any chance.
You might also make sure your distributor is tightened down , and your timing is correct, and make sure you don't have any kinks in your fuel line.
I don't think your problem is from extreme compression, I tend to think it's either timing or carb problems.
Old Dec 5, 2008 | 04:57 PM
smackhonda's Avatar
also check if you have any intake air leaks, or vacuume leaks it could be sucking air causing it to lean way out, that would explain the iratic idle speed.
Old Dec 6, 2008 | 02:54 AM
BuckNeccid's Avatar
Smack, that's probably a better thing to check than what I told him. It's simpler, and way more likely to be the problem. Dunno why I didn't think of that.
Look for hoses coming loose, cracks in hoses, bad gaskets, things like that. You start your engine, then spray something like carb cleaner or again with the WD 40, anywhere there is a vacuum source while your engine is running. If there's a leak, it will pick up the fluid, and your idle speed will change.
Old Dec 6, 2008 | 09:18 PM
challenger's Avatar
hey wyattmerk i think you are right about your tech being sort of out of touch with reality , you might want to check your pcv valve and i would check your timing mark to your rotor position and make sure when you have it at tdc your rotor is on the # one wire on your cap and also check to see how much play is in your t chain by moving the crank back and fourth and see how much it takes to move your rotor...
Old Dec 7, 2008 | 12:02 AM
challenger's Avatar
P.S ..... might sound stupid but i would check to make sure that there is the right spark plugs in it and gaped right as when you have wrong plugs in it they tend to not fire right when they get hot and at pushing speeds
Old Dec 12, 2008 | 02:31 PM
ef8340's Avatar
Senior Member
25/1????????
holy moly i just had to throw that in there
as for me id say what the others posted
goodluck
Old Dec 13, 2008 | 05:59 PM
challenger's Avatar
its more of a holy moly wolie ef hehehehe
Old Dec 13, 2008 | 06:02 PM
challenger's Avatar
p.s------- we didnt run you off here did we Wyattmerk, we are really just trying to help you out and we hope you come back and let us know if you get er going
Old Jan 6, 2009 | 04:00 PM
Polaradude's Avatar
very doubtful on the 25.1, if that's what your builder told you, you might want to get a second opinion on your problem. Or if you know your bore/ stroke head cc etc etc you can calculate comp ratio.
Old Jan 6, 2009 | 04:02 PM
Polaradude's Avatar
very doubtful on the 25.1, if that's what your builder told you, you might want to get a second opinion on your problem. Or if you know your bore/ stroke head cc etc etc you can calculate comp ratio. Or do a leakdown test on the motor.
Rumblefish318
Jun 30, 2013 12:56 PM
trev0006
Jun 12, 2013 04:31 PM
73plymduster
Aug 15, 2010 10:21 AM
racefan55
Feb 23, 2010 09:47 AM
