Installing windshield in Plymouth Duster
Old May 8, 2010 | 10:35 AM
76_roadrunner's Avatar
We are replacing the seal on the windshield of a Plymouth Duster and need to know the proper way to re-install the windshield. Thanks for any help.
Old May 9, 2010 | 12:37 AM
theomahamoparguy's Avatar
I think it is the same as installing a old vw bug windshield. it has a rubber gasket correct?
Old May 9, 2010 | 04:49 AM
mr340's Avatar
Yes, it has the rubber gasket, The install is not difficult. I set the gasket in the frame, using a piece of rope rubbed down with a bar of soap, (don't use liquid it's too messy to work with) place the rope in the window channel starting at the bottom center and ending at the bottom center, place the glass in the opening, setting the bottom in the channel, start pulling the rope out slowly while gently easing the glass into the channel. Don't push too hard on the glass or you will break it. If you don't get it in on the first try, just start over. Remember TAKE YOUR TIME!
Old Dec 2, 2017 | 05:22 AM
LeeMarkus's Avatar
Nothing is different for windshield repair expert they can do repair on both in the same way ..
hink74duster
May 20, 2013 05:50 AM
67rockabillydart
Apr 14, 2009 01:11 PM
ronroddey
Apr 13, 2009 02:08 AM
jane1043
May 8, 2008 07:11 PM
Wonsley69
Feb 22, 2008 04:39 PM
