Installing windshield in Plymouth Duster
Old 05-08-2010, 10:35 AM
76_roadrunner's Avatar
We are replacing the seal on the windshield of a Plymouth Duster and need to know the proper way to re-install the windshield. Thanks for any help.
Old 05-09-2010, 12:37 AM
theomahamoparguy's Avatar
I think it is the same as installing a old vw bug windshield. it has a rubber gasket correct?
Old 05-09-2010, 04:49 AM
mr340's Avatar
Yes, it has the rubber gasket, The install is not difficult. I set the gasket in the frame, using a piece of rope rubbed down with a bar of soap, (don't use liquid it's too messy to work with) place the rope in the window channel starting at the bottom center and ending at the bottom center, place the glass in the opening, setting the bottom in the channel, start pulling the rope out slowly while gently easing the glass into the channel. Don't push too hard on the glass or you will break it. If you don't get it in on the first try, just start over. Remember TAKE YOUR TIME!
Old 12-02-2017, 05:22 AM
LeeMarkus's Avatar
Nothing is different for windshield repair expert they can do repair on both in the same way ..
hink74duster
05-20-2013 05:50 AM
67rockabillydart
04-14-2009 01:11 PM
ronroddey
04-13-2009 02:08 AM
jane1043
05-08-2008 07:11 PM
Wonsley69
02-22-2008 04:39 PM
Quick Reply: Installing windshield in Plymouth Duster
