NEED HELP REMOVING DRIVESHAFT!
Old Aug 11, 2008 | 10:11 PM
chlngr1970's Avatar
There should be two straps that hold the drive shaft to the rear pinion shaft. These are two straps that are helds on by two bolts each.
The green shaft bottom left is the drive shaft, the blue part it attatches to is the pinnion shaft. The strapps should be on the pinnion shaft side around the U-Joint. With those straps off, you should be able to pull the drive shaft foreward enough to get it out, and drop it down. Then you just slide it out of the tranny.
j
klayton9
Aug 20, 2012 06:07 PM
Dereklovesalishia
Nov 7, 2011 04:47 AM
66 A100VAN
May 14, 2010 08:29 PM
67 GTX
Sep 6, 2008 07:30 AM
ccflash22
Nov 12, 2007 04:22 PM
