i bought galvanized steel 14 gauge wire from lowes and made the coils myself, anyone think these will be a problem, a little thicker than than old ones not by much if it is not strong enough any suggestions on what to use
The old coil I took out was just starting to show a little rust after 40 years, not too bad I guess, I am a little iffy about the wire it is thicker but just seems softer than the original.
The coil in the lower hose is spring steel made of stainless steel I would not use wire..Reuse the old spring/coil and put it into the new hose...Why don't they come with the coil in them anymore???? Bill
Ok problem solve stupid me forgot flex hose has the spring, bought it for $10 cut the hose open took the spring put it in the A/C Coolant hose. Fits perfect and the length is exact. Needed the ac hose because I upgraded to a 26" radiator.
Quote:
Why isn't it needed??? You put these comments in like you are some kind of wizard or something..Originally Posted by moparted
because its not needed
.I guess they put them in there because they had a whole bunch of left over Slinkys that they needed to get rid of...And those stupid engineers what the hell do they know...If you take the coil out of the lower hose when the RPMs increase the lower hose will collapse and restrict the flow of coolant causing the engine to run hot and or overheat.. Unless you are Joe cob job and use a universal flex hose which looks like chit...
