rear drum interchange
Old 04-13-2011 | 04:07 PM
breckjar's Avatar
Anyone know if you can put 11 by 2.5 inch drums and shoes on a rear end and axles setup for 11 by 2 inch? Possible issues with axle flange clearance? Any help would be appreciated!!
Old 04-13-2011 | 05:01 PM
bboogieart's Avatar
I believe that the backing plates determine the width of the shoes. To many axle sizes other wise. If so you will not be able to use the 2.5 drums unless you change the backing plate as well. Measure the backing plate to the axle flang where the drum seats and compare to your 2.5 drums.
Old 04-13-2011 | 11:30 PM
There is really no reason to go to wider 11" rear drums. It is a direct bolt on, just use all of the matching hardware..
Allens366
11-09-2014 08:33 PM
breckjar
09-28-2011 10:36 PM
Bossta
10-06-2009 10:56 AM
JLanzino
02-27-2009 10:49 AM
ramhead
09-11-2008 08:57 PM
