replaced timing and still wont start 99 1500
Old Nov 6, 2010 | 12:30 PM
covington's Avatar
was goin down the road the truck shut off and backfired a few times replaced timing chain and wont start and cranks real slow did a compresion check and got numbers from 60 down to 15 did not do with oil in cylinder yet but going to do that now would be thankful for any help i am not a mechanic but thought i could handle this job
Old Nov 6, 2010 | 06:24 PM
challenger's Avatar
what engine you have and did you put the distributor back in right
Old Nov 6, 2010 | 06:30 PM
scotts74birds's Avatar
I'm REALLY HOPING that you did the compression test wrong. For your sake.
Old Nov 6, 2010 | 06:41 PM
blue 68 gts's Avatar
Yep... but it's pretty hard to do a compression test wrong... Maybe he did a leak down test instead?
Compression should usually be around 130-150 in all the cylinders..
And all oil in the cylinders will do is help make the rings set. It'll give a bit better of a reading, but not ALOT.
74Runneer
Jul 29, 2014 03:22 PM
marcello7x
Oct 5, 2013 11:17 AM
kevinjmay
Jun 19, 2013 05:55 PM
Gorts 5th
Dec 19, 2012 04:52 PM
62Furious
Sep 6, 2011 04:35 AM
