Rust Repair
Rust Repair
Hello,
So on my 68 Newport, I do have quite a bit of rust in the trunk (really the only place with bad rust on the car). A friend who does a lot of work on cars recommended that I use this stuff called "Rust Bullet". I read up on it and it sounds very promising. Has anyone had any luck with this stuff?
Thanks!
Thanks!
Hello,
Thanks!
Thanks!
I'm assuming your not talking about repairing the rusted areas just trying to stop the rust from getting any worse? If this is the case yes I have heard good things about rust bullet, I personally use POR 15 but I think the products are somewhat similar. Obviously the right way to do it is to replace the sheetmetal but to help stop the spread of the cancer till you can replace the metal its a good idea
again this is temp. fix
if you have a lot of pin holes and a patch job isn't in the works . quick fix with rust bullet/por15/kbs/magic paint is DO all your prep and lay down your firts coat, while tacky lay down a sheet of woven fiberglass mat on top and press it in with the wet brush making the mat all black. aplly a coat or two after when it gets tacky. verry stiff and gives the "paint" something to adhere to instead of flowing out the pin holes. did this in my trunk and front floor boards as a temp. job 4 years ago. still holding up and not leaking water in or out. it is a 'cut out' when i get around to doing the correct right propper repair, but it got the car ,which is my daily ride, on the road.
73Monaco
May 27, 2014 03:13 PM
dnlwstwd
Oct 12, 2011 08:08 AM
