Sander? Wire Wheel? Chemicals????
Old May 16, 2009 | 10:54 AM
scotts74birds's Avatar
Again, X2 for me.
Old May 16, 2009 | 10:55 AM
BuckNeccid's Avatar
Lots of different ways to strip a car, DA with 80 grit, some of the black nylon looking wheels that kinda look like a funnel cake (they actually work pretty good) and like you mentioned, chemicals. There's even a grinding wheel that looks like a lot of flaps of paper overlapping in a circle, if it's a fine enough grit (like 80-100) it works great to strip with as well, while leaving a good surface to let the paint adhere. I always try to make the stripper the last resort, less mess to clean up, and less chance of any residue being left to mess up your new paint.
You should have some sort of a surface to let the new paint adhere to, just as a rule of thumb, take a piece of 400 grit sand paper, sand some of the area you've already stripped, and the way the surface looks after that, aim for the whole car to look that way when it's stripped.
Old May 17, 2009 | 09:17 AM
69Fury3's Avatar
I am actually trying to do the same thing. However, i am not planning on having the car painted until next year (until i have the money). The car is stored in my driveway under a cover and i am afraid of having the car in primer until next year because i am afraid that water will get through the primer. Is there a certain kind of primer or sealer that can be used that will block out water that anyone knows of?
Old May 17, 2009 | 12:27 PM
Polaradude's Avatar
There is an epoxy primer you can use.
Old May 19, 2009 | 04:46 PM
Commando's Avatar
I use a stainless steel knotted wire wheel on my grinder and haven't lost many wires, and I have done a rear, jeep tub and some other various parts.
Old May 20, 2009 | 07:25 AM
Crazy4Carz.Com's Avatar
Nah!!!! Stop!!! Why so much trouble? Almost everytown USA has a media blaster that will do this job. I have had it done on three cars so far, and it is awesome. No sand blasting, these guys know what to use. they use a concotion of soda, plastic beads, walnut shells... the body never gets distorted from heat (a problem you could have from aggressive sanding or wire wheeling) this doesnt show up until after paint and there enough waves to paint fish on! Every car I had blasted cost between $200-$300. Add up the chemicals, sand paper, wire wheels and time, not to mention potential damage to the body. going to the stripper makes the most sense. Ask around at body shops and get referals, you will be surprised how easy and fast it is and how clean and nice it comes home.
Old May 20, 2009 | 11:36 AM
Is blasting practical for doing a section of the car, rather than a full teardown?
Old May 20, 2009 | 01:22 PM
mopar nate's Avatar
wen i striped the engine bay i used aircraft stripper get it at like car quest it like 10-15 buck paint it on let it sit for about 20-30 mins and the **** flakes off use like a dry wall spade
Old May 20, 2009 | 01:38 PM
I got some stripper from Napa, but I cant get the car to run, and I dont want to use it in the garage. once outside the garage door the driveway goes down FAST! Cant push it back in.
Old May 20, 2009 | 02:29 PM
mopar nate's Avatar
yea that might be a bit of a issue lol nvm
Old Jul 4, 2009 | 01:29 PM
Originally Posted by johnberetta
Airplane remover from autozone and a one inch putty knife for me. my garage has no electricity and i am broke. but it does the job really well just tedious.
I used aircraft striper on the wheels for the j10 and all I can say is HOLY CR@P! That stuff worked great. As for usig it on hte body of a car though....... maybe just the underside and lower body panels.
Old Jul 5, 2009 | 10:53 AM
theomahamoparguy's Avatar
Yeah a wire wheel works if the paint aint too stubborn. Ya gotta be cautios with it, it'll try and bite you [especially when you remove the saftey gaurd].If you got a DA that works too on the outside body paint {use 40 grit to start then switch to 80}.You can "lock out" the orbiting part so it just spins. Media blasting is the best if you can do that. Also if you have a buffer/polisher {sander} you can get a large foam backed sanding attachment wich you can than attach large sanding discs. I think maybe all the way diwn to 24 grit. [Dont grind the metal with the 24 grit, just the initial top coat.] For the buffer/sander try a pawn shop or Harbor freight. ($29 at harbor freight)
Crazy4Carz.Com
Jul 14, 2009 03:26 AM
GMdude
Jul 9, 2009 04:42 PM
74cuda
Jun 14, 2009 08:49 PM
oddesttmouse
Aug 24, 2008 07:44 PM
hemi165
Jun 24, 2008 11:40 PM
