starting the old beast
well if you read my intro you will know the whole situation with getting this thing started.
the fluids were drained before it sat so im thinking new fluids,new spark plugs and also spraying wd 40 into the cylinders and turning it over by hand before starting then put a new battery in it, unhook the fuel pump (gas line leaks) just add gas to the carb and try to get it cranked up. anything else i need to do? |
clean the carb, maybe drain the tank/lines. and prime the oil pump. should be good to go.
Originally Posted by 66sportfury
(Post 13990)
instead of WD40 I would use Marvel Mystery oil
Originally Posted by 78D200
(Post 14016)
to prime the oil pump, the intake manifold needs to be taken off
Originally Posted by 67 GTX
(Post 14029)
it would probably be best for the engine
it sat for so long, all the oil probably drained down to the oil pan did you change the oil? |
Use Marvel in the cylinders. Pull the plugs and squirt in a few drops. THat will help the rings seal up better that WD40.
(Post 14033)
if it sat for so many years, valves probably rusted together
same thing happened with my car |
so is it still possible it will run?
yes
you have to carefully bare the engine over by hand first while doing it, if you feel resistance, back off, they try again easier |
heres what i should do in order, correct me if i am wrong
put new fluids in put a few drops of oil into the cylinders turn over by hand making sure nothing is binding new plugs disconnect the fuel pump put a battery in it add fuel into the carb attempt to start it |
ya, that seems good
when baring it over by hand, if you take out the spark plugs, it'll be easier for you |
ok
what kind of oil do you guys reccommend for a car like this?
you should read this: https://moparforums.com/forums/f62/o...-engines-2333/
so i need oil with zinc additive? anything else special? what weight etc... should i get
i use rotella T its a 15-40
i also use a zinc additive |
alright im gonna try it all next weekend. how do i turn it over by hand i dont think i can get a socket down there or can i?
you put a breaker bar on the bolt that holds the crank in
do you happen to know what size the bolt is?
hmmm, not exactly, but it is a BIG bolt
around an inch or more maybe |
i hope i can get a breaker bar down there im not sure if its possible with out removing the radiator. counter clockwise or clockwise?and how many times should i turn it over
you should be able to do it
you go clockwise turn it over a few times, enough so the pistons move freely |
should itbe hard to turn or easy or in the middle?
if the spark plugs are in, it'll be hard
remove them, and it'll be in the middle (you still are moving all the metal, so it wont be easy) |
should i add the oil before or after i turn it
before
