timing chain cover
Old Apr 3, 2010 | 03:23 PM
recondotexas's Avatar
timing chain cover
I am about to change my water pump and I noticed a slight leak around the timing chain cover on the block side, since ive never done it, how tough is it to change out that gasket? Thanks
Old Apr 3, 2010 | 03:37 PM
its pretty easy
it is just a few bolts
once it is off, you can also check out your timing chain
but be careful
it is sealed on the bottom by the oil pan gasket (in my case)
Old Apr 3, 2010 | 03:44 PM
rdrunner1974's Avatar
timing cover
You will need to remove the dampener pulley from the crank. You can borrow a puller for that from Autozone. Along with the cover gasket, replace the seal for the dampener. Buy the gasket and seal from Autozone in exchange for the puller loan.
You may have to leave a deposit and they return it when you return the puller.
Gorts 5th
Dec 19, 2012 04:52 PM
chaneyclan
Jul 11, 2012 01:05 PM
lifted150
Jul 8, 2012 10:29 PM
teedeej340
Dec 1, 2010 06:16 PM
roadwarrior86
Oct 11, 2010 11:40 PM
