17 volts?
Old Oct 3, 2013 | 05:17 PM
440 aspen's Avatar
17 volts?
So driving home from work today i noticed my car was charging at 17 volts and going crazy. Its a 440 and it only does this once in a very rare occasion. can anybody tell me what would cause this? thanks
Old Oct 3, 2013 | 05:40 PM
Voltage regulator or alternator.
Old Oct 3, 2013 | 05:49 PM
moe7404's Avatar
your bit bucket is full. just dont let the newtrons use the red wire.
Old Oct 3, 2013 | 06:44 PM
There are several things that can cause this...............
What year / model are we workin' on, and what alternator / regulator do you have?
Old Oct 3, 2013 | 07:26 PM
Silverick's Avatar
Was the battery low? My Fury will charge a little harder on occasion if the battery is low and then, once the battery is back to full charge, go back to normal...
Old Oct 4, 2013 | 02:06 PM
440 aspen's Avatar
The car is a 1980 dodge aspen that i crammed a 440 into. the alternator came with the engine when i bought it so i dont know much about it other than it works. its my daily driver and had no problems starting and driving so i know the battery wasnt low. the voltage regulator is stock to the car but has worked fine the past 8 months ive been driving it.
Old Oct 4, 2013 | 02:22 PM
It should have a two field alt. SO the reg is probably bad and the battery too !!!
17V will kill the battery in short order
Old Oct 4, 2013 | 03:37 PM
omgomgomg that's sooooo cool. Please a pic?
Old Oct 4, 2013 | 05:34 PM
IF it only happens once in a while????
I'm going to say... It needs a battery... I would rule it has a plate loose in there causing your intermittent problem....
Just my 2 cents
Old Oct 5, 2013 | 10:34 AM
slade's Avatar
mopar regulators are cheap enough i would change it also what would it hurt?
70ChallengerJoey
Feb 17, 2013 06:15 AM
