1975 225 small port head?
Old Nov 22, 2022 | 07:37 AM
808mopar's Avatar
Hi,
Did Dodge change the head runner size on 1975 225 Slant Six?
Thanks
Old Nov 23, 2022 | 10:43 AM
Kuvasz101's Avatar
They did change the head design in 75 or 76. The way to tell is the newer design had small (peanut plugs). The older design has larger plugs that have the metal inserts that go inside the head with an O ring around the insert with the spark plug going inside it. The newer engine actually was built a little less beefy or sturdy than the older design but still a very good engine.The older design had wider connecting rod bearings.
Old Nov 23, 2022 | 03:58 PM
808mopar's Avatar
Thank you for the tip identifying the two heads.
Old Nov 23, 2022 | 07:13 PM
I’m not sure but the bearings are narrower but the rods the same, I believe change’s were made to increase fuel mileage or to make the bean counters happy. A few times I’ve read up on the /6 heads I haven’t seen a good 225 head or a bad one. I know chamber sizes changed over the years with engine size.
Old Nov 25, 2022 | 06:05 AM
Kuvasz101's Avatar
One important note if using the stock exhaust manifolds. There's a clamp that secures the exhaust pipe (located about a foot downstream from the header exhaust flange) that attaches to the engine. If this clamp is missing, broken or neglected the weight of the exhaust will always break or crack the exhaust manifold.
Beeboy
Oct 30, 2022 12:15 PM
The old mans garage
Mar 30, 2020 11:33 AM
SspazZ
Jul 29, 2014 09:15 AM
1966DartConvertible
Aug 6, 2010 09:03 AM
1974duster
Feb 21, 2007 07:16 PM
