318 with 360 heads
Old Feb 4, 2009 | 03:13 AM
Any intake manifold from a chrysler/dodge/plymouth 273 through 360 small block LA motor will fit. The heads are a good swap specially if you plan on swapping out the cam.
66 - isn't there a set of J heads (or something) that are best?
Old Feb 4, 2009 | 03:28 AM
Polaradude's Avatar
I think the J's are the ones.
Old Feb 4, 2009 | 12:53 PM
1 Bad Mirada's Avatar
Administrator
technically, X heads are the best...but like the J and U heads, theyre expensive, and getting harder to find. for how ive seen them priced, its better to get a good set of heads. also, those heads were only "great" for what they were...modern technology has left them behind, unless your goal is to use a stockish mopar head.
i have 88 360 truck heads on my mirada, 1.88/1.60 valves, ported, and ive been very happy with them. the mirada makes substantially more power than my demon 340, that has 73 340 heads.
Old Feb 6, 2009 | 04:57 AM
Administrator
my understanding is that any non-magnum small block head will fit any non-magnum block, from 273 to 360. i know that a magnum head will fit a non-magnum block, but it takes some machining work, i believe? something like the bolt pattern has to be altered? as an owner of both magnum and non-magnum small blocks, i cant imagine why i would EVER put a magnum head on any of my older LA engines. honestly, i would LOVE to rip the magnum 360 out of my wifes truck in favor of my ramchargers LA360. there is a ton more bang for the buck to be had from the LA engines.
Old Feb 6, 2009 | 05:02 AM
I believe that the water passages or oil paasages do not line up either (its one of the other) between the LA and magnum heads. I have yet to build a magnum motor but I know it there is a lot more performance options out there for the LA motors than the magnum motors.
On a side note, I did see a hell of 360 stroker motor in a 98 jeep GC. All I can say is that jeep threw you back in the seat when you stumped on the go pedal.
Old Feb 6, 2009 | 01:42 PM
Administrator
my 88 360 heads were "swirl port"...but i dont know what size the combustion chambers are...that is what makes the difference on the compression...
Old May 23, 2009 | 12:31 AM
deadkelly's Avatar
yeah 500 2bbl ok we use em a bit on our 245 & 265 hemi 6s
afro
Sep 2, 2011 12:33 PM
vengence99
May 27, 2011 06:14 PM
recondotexas
Dec 31, 2009 10:12 AM
1973charger
Jun 4, 2009 09:46 AM
lail12
May 26, 2009 07:20 PM
