318 poly intake
Old Dec 30, 2011 | 03:09 PM
66coronet440's Avatar
318 poly intake
Hey guys just want to know what i would also require if i go ahead and buy a 318 poly 4bbl original intake (single carb)? i found one for $200 is it worth it? Casting number is 1859229... thanks.
________________________
1966 Coronet 440 318 poly
Old Dec 30, 2011 | 06:16 PM
It's worth it if you need one. They are getting harder to find...
Old Dec 30, 2011 | 07:43 PM
Ok what kind of carb can i put onto that? Do i need an original? Do i have to change my cam?
Old Dec 31, 2011 | 07:17 AM
Depends on what you find. I'm sure a few of the older ones only had the so called narrower bolt pattern for the early Carter style, but you can buy an aftermarket adapter even for those, that would allow putting a Holley on if you want. If you found a later aftermarket Weiand or something, it probably would accept both bolt patterns. Even so, if you wanted to run a spread bore carb, you can get adapters
Just one type of spread bore adapter. Notice the 8 mounting holes. This illustrates the two popular 4 bbl mounting patterns. Some early manifolds had the narrow pattern, typically for Carter AFB or on smaller engines, even smaller carbs
Old Jan 2, 2012 | 08:03 PM
Oh Thats great thank you very much for that info!
snowtrooper1966
Nov 20, 2013 06:39 PM
snowtrooper1966
Sep 12, 2013 11:17 AM
Silverick
May 25, 2011 05:55 PM
TallChris
Dec 1, 2010 03:29 PM
Monacoman
Jul 24, 2010 07:53 AM
