318 pushrods
Old Jul 28, 2010 | 09:44 PM
Cracocuda's Avatar
Question 318 pushrods
I change the cam of my 318 to a one with more lift and duration( hydraulic). When I tried to install the valvetrain (the stock 1.5) I notice that I will need a larger set of pushrods. A friend told me that a set of adjustable pushrods will work.Another friend don't recomend me the use of adjustable,but he don,t know the true reason. I may go for a set of adjustable rocker arms, but this is a more expensive solution. Please I accept recomendations for this issue.Thanks
Old Jul 29, 2010 | 03:45 AM
Crazy4Carz.Com's Avatar
Get an adjustable to figure the length, then order a set made to the correct length.
Old Jul 29, 2010 | 09:57 AM
Cracocuda's Avatar
Post 318 pushrods
Yes, this is another way, but where I can find the pushrods in the exact lenght? Have suggestions?Thanks for the advise Crazy4Carz.
Old Jul 29, 2010 | 10:26 AM
Most any local speed shop can order them for you. If you don't have anyone local, try Jeggs or Summit.
Old Jul 29, 2010 | 02:03 PM
Ellis Wyatt's Avatar
Depending on length, I have a set new in box from ma mopar that might work.
Any idea of the length needed?
Old Jul 29, 2010 | 02:39 PM
Cracocuda's Avatar
318 pusrods
Thank's Crazy4Carz, first I'm going to find a pushrod lenght checker and later I will try Summit or Jeggs.The stock pushrod lenght is 7.5", I think I will need something near 7.58"
Old Jul 29, 2010 | 02:46 PM
Cracocuda's Avatar
318 pushrods
I'm not sure,I need to find a pushrod lenght checker first to go by the book. The stock lenght of the pushrods is 7.5",maybe I will need something near 7.58" or 7.6" The set that you have what lenght are? Thank Ellis.
Old Jul 29, 2010 | 04:54 PM
1966sportfury's Avatar
A.K.A Bob Dodge
odd, i never ran into a problem with changing cams, never had a pushrod issue,
did you run it like that or just bolted them down and they were a lil loose.
mrzods13
Mar 16, 2014 09:48 AM
Fratzog
Feb 22, 2013 12:07 AM
69POLARA383
Jun 26, 2012 05:31 PM
merkfalc
Jan 16, 2012 11:59 AM
67gtxclone
May 2, 2010 09:27 PM
