318 tbi to carb conversion?
Old Sep 5, 2019 | 09:12 AM
Johnnytrump's Avatar
Thumbs up 318 tbi to carb conversion?
Hey all, new to this forum. Im close to pulling the trigger on a ‘90 w150 with the 4 speed manual and tbi318. I want to swap out the tbi system for a good old carburetor, but im not sure exactly what I would need. Fuel pump? Distributer? I posted this in the DIY section, im hoping it may get more attention here.
Old Sep 5, 2019 | 11:00 AM
I'd be tempted to use the stock fuel pump with a ajustable return regulator for a carb.
Old Sep 5, 2019 | 11:29 AM
alright thanks, sounds fairly simple, what should I do about the computer bits? just let them be?
Old Sep 5, 2019 | 03:28 PM
Not sure how much works and doesn't.
Old Sep 5, 2019 | 03:42 PM
I did this with a 1992 and Tom is right. I ran two fuel lines up the left frame rail and mounted the regulator just under the brake power booster. Wiring is a bitch, I spent a lot of time trying to incorporate the computer and charging system into the change, DON"T. I put and old style alternator with regulator in and the computer stayed in just to run the dash gauges. The three relays I switched around so it would start like an older vehicle, key on powers relay to start fuel pump and power a ballast resistor, key start powers relay to start starter and 12 volts to coil, basic stuff.
The 4 speed manual makes this much easier. We had autos, Magnum 5.2's, and finished with a nice 318 + .030" with a manual 4 speed O.D. and hydraulic clutch. Removed the rusty box and built a flatbed, put in a Auburn LSD and changed the 3.91 to a 3.55 in the 9 1/4 rear axle. That was a great POS hard working truck, I loved that thing man.
Crazy4Carz.Com
Oct 2, 2010 06:40 PM
gcastellana
Nov 16, 2009 10:37 AM
