383
Old Sep 3, 2010 | 02:30 PM
g cheek's Avatar
383
I just power washed a 383 in the GTX I found setting for 20 years.Not the original 440 so already disappointed. Take it on a test drive, open the hood to find puddles of oil on the front of the block below the intake. Is this a bad gasket some where?
Old Sep 3, 2010 | 03:11 PM
1966sportfury's Avatar
A.K.A Bob Dodge
sounds like it, intake or valve cover
Old Sep 3, 2010 | 05:19 PM
blue 68 gts's Avatar
Or the valley pan could be cracked..
Old Sep 4, 2010 | 04:08 AM
I would say either valley pan and/or valve cover gaskets. Both are very easy to replace and are cheap enough. I would do both and call it a day.
Old Sep 4, 2010 | 05:10 AM
rdrunner1974's Avatar
gasket
I had the same issue. The intake/valley pan was cracked under the intake where it could not be seen.
You may want to get a gasket that blocks off the heat cross-over. Use silicone on the front and rear.
labradorian70
Sep 24, 2014 09:44 AM
