383 street performace Rebuild
Old Nov 29, 2010 | 03:18 PM
DandyD's Avatar
Greetings,
I am coming to the final stages of my 383 rebuild and was just wondering if anyone could give me an idea of a realistic power output range since I may not have access to a dyno. Here are the stats:
67' 383 block bored .60 over and milled
Factory forged 383 crank and rods
KB flat-top pistons with valve reliefs
67' factory 516 closed chamber heads short-ported and polished with stainless steel over-sized valves. Milled and gasket-fitted for a comp ratio of 9.9-1
Roller rockers.
double roller timing set
Comp flat tappet 280 Magnum cam
Edelbrock Performer RPM intake with 650 Thunder carb
Hedman headers
I think that's everything. Any thoughts or ideas would be appreciated.
Old Nov 29, 2010 | 07:35 PM
Archer's Avatar
DD -
Impossible to say with any certainty. Things like header primary diameter, type of exhaust configuration post header and what you have hanging off the engine all factor in. (also didn't mention cam lift)
The 650 carb may not he your best choice, but people do go that low with good results (there's more to a carb than just cfm).
Gut reaction, if everything is tweaked, 400 - 425 HP at the flywheel, maybe 100 less at the rear wheels, but don't take those numbers too seriously.
Old Nov 30, 2010 | 02:06 PM
here's an important question: what rpm range is your cam? 2000-5500?
Old Dec 2, 2010 | 08:56 AM
DandyD's Avatar
383 Street Performace Build
The cam is 280 duration, 480 lift at 2500+ RPM.
Old Dec 2, 2010 | 01:45 PM
blue 68 gts's Avatar
650 will be just fine imo...
Old Dec 2, 2010 | 02:30 PM
i would guess around 400-425 at the flywheel
tbarnett88
Oct 15, 2014 01:52 AM
labradorian70
Sep 24, 2014 09:44 AM
Roxanne Gstad
Mar 12, 2013 03:22 PM
NYH1
Jul 2, 2009 11:03 AM
MrMopowered
May 9, 2009 11:31 AM
