4 speed
Old Mar 1, 2013 | 05:14 PM
dboykin's Avatar
4 speed
Ok guys I have some questions I have a 440 and a 4 speed I want to put in my 1970 plymout fury iiiwhich currently has a 318 and a 727 . ? The 4 speed is a b body transmission I believe will this work for me and will the b body cluch/brake pedal *** work any info is very much appricated
Old Mar 2, 2013 | 12:21 PM
jacilynn_s's Avatar
the fury is a c body. Will the engine and transmission fit yes with c body mounting brackets. Will the clutch pedal fit no. You need the clutch bolt on bracket that goes beside the steering bracket from a cbody as well as the brake pedal.
None of the b body linkage will fit either.
Old Mar 2, 2013 | 05:32 PM
bigblock's Avatar
The engine and trans will bolt right in. Clutch linkage and pedals will need to be replaced with manual shift parts or heavily modified by a competent welder/fabricator.
Old Mar 2, 2013 | 07:41 PM
dboykin's Avatar
Do u know of a company that makes the clutch pedal assand likage or will I have to make the linkage
Old Mar 2, 2013 | 07:42 PM
dboykin's Avatar
And I greatly appricat the info
71demon360
Jul 20, 2010 08:46 PM
red2bunkeru
Feb 27, 2009 02:25 PM
joel
Feb 22, 2009 07:07 PM
lotus79
Jan 21, 2008 10:44 AM
499coronet
Feb 18, 2007 12:48 PM
