4 speed crank
Old Nov 11, 2009 | 03:30 AM
rr69half6bbl's Avatar
its already drilled for the 4 spd. all cranks were steel until mid 1972, then they went to cast cranks, to cut down on build costs. unless the car was slated for a manual trans after 72, the cranks werent drilled. so yes you can use the 4 spd w/the auto crank for your 66.
Old Nov 12, 2009 | 01:04 PM
johnthegoalie's Avatar
thinkin with me dipstick
use the new mopar roller pilot bearing instead of the bushing. fits in the center large register of the crank. mopar part number #(53009180AB)
Old Nov 12, 2009 | 03:49 PM
scotts74birds's Avatar
Just throwing this out there, but were the hemis internally balanced. Might he need a flywheel balanced to match the motor, or a neutral balanced unit? I've just heard things about mismatching externally balanced motors and flywheels. I'm not saying this may even be an issue for you, but its best to check and ask first.
Old Nov 12, 2009 | 11:38 PM
theomahamoparguy's Avatar
the hemi's were internally balanced. The only difference, I think, is that the hemi had an eight bolt crank [number of bolts holding the flywheel on] as opposed to the 440 that had the six bolt crank. so you gotta use the correct flywheel. If you use the "hemi" four speed. [as some call it] you must use the correct hemi bell housing that matches the front bearing retainer of the hemi 4 speed. the "hemi" four speed had the 18 spline input shaft as opposed to the regular one that had the 23 spline.
Old Nov 13, 2009 | 02:26 AM
Polaradude's Avatar
I have all the bell housing casting #'s if you aren't sure what you have.
Old Nov 14, 2009 | 10:47 PM
just a side note: The Hemi 4 speed was also used behind the 440's for the high performance applications. Example would be a 69 charger with hp 440 with a 6 pack or 4bbl and a dana 60.
Old Nov 16, 2009 | 02:31 PM
like my car
atowncris
Nov 19, 2009 12:48 PM
Demented
Jul 23, 2009 03:59 PM
joel
Feb 22, 2009 07:07 PM
CLJohnny
Dec 12, 2008 11:45 AM
Pito's 74
Oct 5, 2008 11:29 PM
