413 ?
Old Sep 5, 2012 | 08:16 PM
dboykin's Avatar
413 ?
i have recently got my hands on a 72 413 and it came with a set of 440 heads the heads need to be totaly rebuilt and was wondering if there were worth it. i want a high performance motor but not really wanting to spend years building it new to site so any advice is hellpful thanks in advance
Old Sep 5, 2012 | 09:32 PM
Save some money first. Rebuild the heads. Throw them back on the 413 and see what she will do.
Old Sep 5, 2012 | 10:32 PM
Probably a typo.. a 413 is 1962 base for the 413 MaxWedge motor. Yes it is worth building !!
Old Sep 6, 2012 | 07:05 AM
dboykin's Avatar
Also this motor came out of a motormen home and I know on some the can turned backwards but I can't tell becase it dose not have the water pump so is there any sign besides the water pump
Old Sep 6, 2012 | 07:46 AM
Aw, come ON. 413s and 440s were used in MANY trucks and motorhomes. Just because you have "an engine" does not make the thing an HP engine.
"Maxi" engines were mostly pistons, cam, heads an intake, all expensive pieces, and certainly not what you'll find on the average 413/ 440
If he's unlucky enough to have the "different" heavy truck heads with the "high" mount water pump, what he basically has here to start with is a block and a crank.
Old Sep 6, 2012 | 10:14 AM
dboykin's Avatar
Ya 440roadrunner your right the block and crank r really the only thing worth useing and the 440 heads came off a car or so the Guy says it has dish pistons and is just a block crank pistons and heads
Old Sep 6, 2012 | 10:40 AM
dboykin's Avatar
20780915-3 r the head casting numbers
Old Sep 6, 2012 | 10:44 AM
dboykin's Avatar
272780915-3 aadadd Sorry a zero by mistakethere
Old Sep 6, 2012 | 02:57 PM
-3 indicates a heavy truck engine.
Old Sep 6, 2012 | 03:33 PM
What is/are the casting numbers on the passenger side of the engine block?
Old Sep 6, 2012 | 07:38 PM
moparted's Avatar
413 pistons are very expensive, get a 440 to build
Old Sep 6, 2012 | 07:49 PM
dboykin's Avatar
Ill have to look on block tomarrow ob the outher head instead if 3 it has a 4
Old Sep 6, 2012 | 07:55 PM
dboykin's Avatar
dadad ssasaysays 440 r good motors but I want something different than what other people have
Old Sep 6, 2012 | 08:47 PM
dboykin's Avatar
Correct me if I'm wrong but from what ive red I have a set of desireable 915 close chamber heads sorry for all the stupid questions but never built a big block molar before and want to do it right
Old Sep 7, 2012 | 04:16 PM
Gorts 5th's Avatar
Talking
sounds like what u need is a set of 413 max wedge heads ....closed chamber
well never sell ours
Old Sep 8, 2012 | 05:24 PM
moparted's Avatar
wait to u price the pistons and have basicly no choices
Old Sep 8, 2012 | 05:51 PM
dboykin's Avatar
I already have and I found some forged and cast flat top
griz2575
Jun 24, 2008 06:13 PM
glennmccann
Jan 3, 2008 11:04 AM
poolinstaller
Oct 27, 2007 07:34 AM
poolinstaller
Sep 13, 2007 05:23 AM
Cardude
May 2, 2007 03:57 PM
