413 RV heads
413 RV heads
Hi Everyone,
I have a set of 413 RV heads that had a valve job . I was thinking of putting them on the 413 in my imperial, and wondered if they would work. The heads look to be the same overall size. The RV heads have extra water ports which would I think would be blocked by the std head gasket. The valves int he RV head look a little larger, but I am not sure about this . Anyways, I was wondering if this swap will work, and if anyone has experience running RV heads on a std engine
Thanks, I appreciate any input you might offer.
The original head's are close chamber the rv head's are open chamber so your going to louse .75 or more in compression. That said the rv are better flowing larger valves etc..
Your and most 413s were designed to use the small chamber head's.
Please rebuild the original head's.
Let me help... The part where your finger is laying across is called the quench pad. The one without the step is an Closed Chamber head.... The other head with the step, is a Open Chamber.
452's are a 2.08/1.74 open chamber head = lower points in compression.
76-78 400/440
516's are a 2.08/1.60 closed chamber head = More compression.
64-67 361/383/413/426
And somewhere in there there was a small valve 440 head? I dont remember if it was Open Chamber or Closed Chamber. But I cant remember and I'm to lazy to go look....lol
I would say for what your doing with the car. Jusr rebuild the OEM heads and call it a day. Just my 2 cents. 413's run pretty good. But if your going to hop one up. Do the whole motor and put all the rite parts in it from the get go.
76-78 400/440
Yes, Unless you build the whole engine for performance.
If your thought is just head swapping, Your more than likely not going to feel much if anything in the seat of your paints.
poolinstaller
Oct 27, 2007 07:34 AM
