440 oil pressure
440 oil pressure
how much is too much? i am at about 45-50 at idle and been around 82psi cruising but today it hit 90 psi. i can not find anything that tells me what too much is. A friend told me 100 psi and it will blow the gaskets and seals out. Help?
Your relief valve must be stuck. I think you need to remove the oil pump to get to it (?) I have never needed to access the relief valve of the oil pump. How much is too much? I think the pressure gage may go first.
dzltd02
Oct 28, 2008 08:25 AM
