440 Wt
Old Dec 5, 2012 | 08:24 AM
raycan2's Avatar
440 Wt
I am taking the 440 out of my Coronet and was wondering how heavy it is...The resone is my freind has a Engine stand that is rated for 1000lbs and said he would give it to me, He bought it and did not use it and still sits in his garage,,,,,So does my 440 wt that much or about 650-700 lbs
Old Dec 5, 2012 | 09:57 AM
You will be fine with that engine stand. Make sure to use grade eight bolts when attaching it to the stand.
Old Dec 5, 2012 | 10:13 AM
BE careful depending on if it is a 3 leg or 4 leg stand. Either one will work...
Old Dec 5, 2012 | 12:04 PM
Nightmare's Avatar
Weighs 670lbs, I thought it would be more then that like around 850. I got mine on a 3leg 1000lb stand but it's leaning forward, so I bought a 2000lb stand from Jegs today for $100 just to be safe.
Old Dec 5, 2012 | 12:08 PM
Mr.4spd's Avatar
Is that fully dressed, ie. Iron heads, manifolds, carb, accessories, etc.? I've always wondered how much this all weighs.
Old Dec 5, 2012 | 04:53 PM
Nightmare's Avatar
Yea all dressed up cast iron everything.
Old Dec 15, 2012 | 06:14 AM
Gorts 5th's Avatar
we have always used a piece of wood to support the front of the engine when torquing down bolts, we never liked the "bounce", so if it was stored over night or if we where working on it we would prop the front with a 2x4 just to be safe. watch those toe's.
